Isn’t Everest called something else? I recall duo or deo as the start.Aoraki, Qomolonga, denali, tahoma, kilimanjaro.
I am fairly sure Kilimanjaros name is subject to some debate, but there is no other name that is given to it consistently
Kilimanjaro sounds like it could be the local name, is that a trick question?
Danube?Which mainland european river has the position of being simultaneously its countries longest and shortest
Nope, need to think a little more outside of the boxVatican City? (The Tiber?)
Not in mainland europe eitherMalta has no rivers
Po?Which mainland european river has the position of being simultaneously its countries longest and shortest
Is the correct answer.
Wow that was out of the box thinking required .Is the correct answer.
Is the longest river in italy, with the shortest name.
The river bed is yours...
It helps when you're told that you have to leave the box.Wow that was out of the box thinking required .
Thank you.Is the correct answer.
Listen to dark side of the moon....on vinylIt helps when you're told that you have to leave the box.
Thank you.
Next question:
I've adjusted:
Vertical tracking angle
Azimuth
Vertical tracking force
Anti-skating
Alignment
What am I now ready to do?
NoLift/Blast off?
More likely to be "In the Land of the Grey and Pink".Listen to dark side of the moon....on vinyl
Edit: should probably also turn off the lights and get comfy
incorrect i am afraid.I'm sure its one of the Baltic states.
Go with Latvia
Denmark is the correct answer having used the same flag since 1219.Denmark?
I'm sure its a Northern European one.
USA. Not it's national anthem as such but a patriotic song that gets sung at times. IIRC it was played at Trump's inauguration. Tune's the same but the words are different. IIRC at least one other country uses the same melody as the UK as its national anthem but its name escapes me at the moment.Which non-Commonwealth nation uses an identical anthem to God Save the Queen?
