Glossop to New Mills Central, have I done something wrong?
unlevel42
5 May 2011
Using my Derbyshire Wayfarer recently I travelled on the X57 bus to Glossop.
I decided to catch the train to New Mills Central from where I could return to Sheffield.
I needed to buy a ticket.
The TVM eventually gave me a ticket for £6 00 with senior railcard.
I went in and out of the barrier at Piccadilly. The gate refused but the gate operator said OK.
Wishing to repeat the journey and to buy online I'm stuck.
I cannot buy a ticket from Glossop via Manchester Piccadilly to New Mills Central at all.
I can buy a ticket from Glossop via Manchester Piccadilly New Mills Newtown and 15 walk and pay extra.
I can make two changes at places in east Manchester for £6.
The ticket I previously bought was:
Anytime Day Single
Valid for one journey from Glossop to New Mills Central
Adult Standard Class with Senior Railcard
£6.00X
Nothing about route or restrictions.
Have I done wrong?
Mcr Warrior
8 Jan 2009
So the question is whether a Glossop -> New Mills Central route "Any Permitted" ticket (SDS) is valid via Manchester Piccadilly, or whether you are obliged to change at an intermediate stations such as Ashburys, or Guide Bridge/Romiley?
A Glossop to New Mills Central ticket is only valid changing at Guide Bridge as far as I can tell. There are easements allowing you to double back between Guide Bridge and Piccadilly if you are travelling to Stalybridge or beyond (as Huddersfield/Hull services do not stop between Piccadilly and Stalybridge), but that is not relevant to your journey.
There is no way that a passenger could realistically be expected to know this. Certainly, if it happens to be fastest to go via Piccadilly at the time you depart (which it currently often is, given the limited frequency of the Rose Hill Marple service), it would be quite unreasonable to suggest that you can't do that.
30907
Testing this on NRE (set to Avoid Piccadilly), the fare is not valid via Ashburys.
With the current timetable, the route via Guide Bridge offers a 57 minute wait at Romiley, which explains why this doesn't show up.
I doubt anyone would object to your changing at Ashburys (at least in the present situation), Piccadilly involves a double-back though.
Merseysider
Fares Advisor
22 Jan 2014
Whilst Glossop - New Mills Newtown has preposterously overpriced “via Manchester” fares (£25.90 for a day return!) there are no such dedicated fares to New Mills Central.
That said, I personally would have no qualms using a Glossop - NMC ticket via Ashburys/Manchester as it’s a completely reasonable route and I can’t imagine any guard in a million years challenging it. Particularly given that changing at Guide Bridge can also involve a wait of 57 minutes (!) at Romiley.
Mcr Warrior
8 Jan 2009
Presumably on a Derbyshire Wayfarer, depending on the time of the day (obviously!), it might have been possible to get the 61 bus from Glossop to New Mills via Hayfield, without any further fare being payable?
unlevel42
5 May 2011
The Derbyshire Wayfarer is valid on the 61, is a lot quicker, has good views.
On the way to Buxton it goes via Bux(g)sworth which is a short walk to Chinley.
Despite all these attractions I wanted to go by train.
Thanks everybody
Llandudno
25 Dec 2014
Thanks everybody
Could you buy a concessionary TfGM Wayfarer, a bit more expensive at £9.70
unlevel42
5 May 2011
Yes that is a possibility and I have used it several times on other trips.
I am interested more in exploring the potential of the new X57 service between Sheffield (past my house) and Glossop using the £6 70 Derbyshire Wayfarer and returning by a different route.
This is when I found the rail fare from Glossop to New Mills Central confusing.
Mcr Warrior
8 Jan 2009
Not valid all the way from Sheffield on the X57 bus, or beyond Grindleford on way back to Sheffield on the train, is it?
No, but the OP was querying ticketing between Glossop and New Mills Central.
Indeed. Greatest flexibility would be to buy both a GM Wayfarer to use together with a Derbyshire Wayfarer, but quite a bit of overlap in the middle and expensive too!
Ianno87
3 May 2015
I always dreamed of a "Super Wayfarer" being offered that was valid in the combined areas!
Llandudno
25 Dec 2014
Indeed, at £20 it would be fantastic!
But I guess it would have to be priced no lower than the off peak day return between say, Manchester and Derby.
Interestingly anyone aged over 60 can buy the Derbyshire Wayfarer for half price, unlike the TfGM version whereby only ENCTS cardholders are eligible for the concessionary version.
johnnychips
19 Nov 2011
The X57 is quite new. I asked for a concession fare to Mottram from Sheffield (I have a Senior Railcard but not an OAP free pass) which is about two miles into Greater Manchester and I was charged and given a Derbyshire Wayfarer concession ticket, which surprised me.
