Gloucester to Portsmouth Harbour
tigerroar
30 May 2010
Gloucester
I'm looking at booking advance tickets from Gloucester to Portsmouth Harbour and every time it seem to want me to change at Romsey and Eastleigh.
I'm pretty sure there are direct trains from Cardiff to PH via Bristol Temple Meads which I'd join at TM, so why am I being told to get off it at Romsey?
D6975
26 Nov 2009
Bristol
Doesn't do it for me.
Offers multiple changes via Reading and Basingstoke or single change at ST Jn or Filton AW
tigerroar
30 May 2010
Gloucester
STJ, Romsey and Eastleigh. Saturday July 16th
0758 out of Gloucester
Why would it make me get off at Romsey? That's what I don't get.
edit - now that I've put in via BTM it doesn't show it anymore, it's direct.
iantherev
3 Apr 2011
Brecon Beacons
Just tried it on the National Rail Enquiries app - gives me one change at Severn Tunnel Junction -arrive Portsmouth 1152.
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
Short answer: it's not a permitted route to go via Southampton.
Longer answer:
The only map combinations in the routeing guide for Gloucester to Portsmouth Group are:
BL+XR - Stroud, Reading and Eastleigh
BL+XS - Stroud, Reading and Guildford
LG+XR - Bristol, (optionally Bath Spa), Reading and Eastleigh
LG+XS - Bristol, (optionally Bath Spa), Reading and Guildford
The shortest route is via Bristol, Bath, Westbury, Salisbury, Romsey and Eastleigh hence why that is what booking engines are coming up with. Booking engines will also generally allow travel via Southampton on a "VIA SALISBURY" ticket, since they will split the routeing check at Salisbury, and Salisbury to Portsmouth is permitted via Southampton. But if you want to travel on a through "GREAT WESTN ONLY" advance, your only option is to find a GWR train that goes direct from Romsey to Eastleigh avoiding Southampton.
The cheapest way to do this journey on advance fares seems to be to split tickets at Westbury. You can get cheap "GREAT WESTN ONLY" advances on the through GWR trains from Gloucester to Westbury (e.g. leaving Gloucester at 0841) and again on the through GWR trains from Westbury to Portsmouth (e.g. leaving Westbury at 1101). You should be able to do it for £17 or so.
Paul Kelly
16 Apr 2010
Reading
I like the last sentence. £17 from Gloucester to Portsmouth?
It's available for £10 Gloucester to Westbury (or £8.70 if you take an awkward itinerary involving CrossCountry services) and £8 Westbury to Portsmouth the previous Saturday (see attached screenshots from GWR website), so once advances are released for the 16th you should be able to do it for the same price, I'd guess.
crehld
1 Nov 2014
Norfolk
Another option, if you want a bit of flexibility and don't want to be tied to specific trains, is to go for a Freedom of the Severn and Solent Rover which should permit travel over the route you want.
