... Nevertheless, NR appear to be taking the problem seriously and are working with different designers / consultants to produce a series of possible solutions
Looks like their strategy worked then.
Of course you may be right....NR do have form in bull****t*ng about this Project....
As you describe....
Both the North Wessex AONB and the Chilterns AONB are discussing with NR the track in the Goring Gap between roughly Pangbourne and Moulsford where the track cuts through both AsONB, and which is all four track.
The North Wessex AONB are also discussing ( I believe, but could be behind the times ) parts of the line west of Didcot where the two tracks cut in and out the AONB. This section could be easier to resolve - personally, I think that the OLE already installed on the Moulsford Bridge ( which is two, two tracks if you know what I mean ) is a more than adequate compromise.
Smiffy and Gralistair are probably correct - painting, together with appropriate tree planting and screening where possible is an obvious solution. However, there are large areas where screening is not going to work ( particularly looking down into the valley in the Goring Gap from both sides of the river, and along the South Stoke Embankment ) and we've already discussed previously the problems and limitations of retrospectively painting / coating the existing steelwork.
Of course, that's years ago and I'm sure somebody who knows more about modern coating systems may well be able to identify suitable coatings that wont flake off after a few years.
As pointed out elsewhere, galv is a notoriously difficult substrate to coat effectively.
A quick brush over with low concentration phosphoric acid to dull the bright galv. finish very quickly?
Correctomundo - a true etch primer - I think in the 1960s there was mordant wash -same principle. I will be a smart ass later and dig out a formulation even!
Part A
Zinc Tetroxy Chromate 08.00 %
Poly(vinyl butyral) 07.30 %
Isopropanol 48.70 %
Butanol 16.00 %
80.00 %
Part B
Phosphoric Acid 85% 03.80 % Mix Ratio A:B 4:1
Water 03.00 %
Isopropanol 13.20 %
20.00 %
Of course the VOC would be very high but --
Is there a COSHH issue with any of this? What about pollution of an AoONB?
Oh Dear
Not only is the new stuff costing enormous sums of money - now they want to pull some down and replace it. Add another billion pounds to this project.
VOC way high and of course there are substances hazardous to health so Control Of Substances Hazardous to Health not good - and yes it would pollute an AoONB - Of course you could not electrify and allow all those diesel particulates etc pollute the area too - but now I am just being silly and all this really should be in the Goring Gap thread - I think I am up to a quadruple strike with HowardGWR now
VOC way high and of course there are substances hazardous to health so Control Of Substances Hazardous to Health not good - and yes it would pollute an AoONB - Of course you could not electrify and allow all those diesel particulates etc pollute the area too.
Part A
Isopropanol 48.70 %
Butanol 16.00 %
80.00 %
Part B
Water 03.00 %
Isopropanol 13.20 %
20.00 %
Come on...You're better than that.
Unless, of course, you're genuinely suggesting that all freight traffic ( and there's already quite a bit of it and increasing ) should be banned between Didcot and Tileurst, which I don't think you are....
My guess for Goring is that Network Rail will faff about and drag its feet until the new masts have gone a dull grey and started to blend in better. Then once the fuss has died down and the locals are getting used to them. ...
