Ultimately, most of the industry’s spend goes on staff costs or interest payments one way or another.
Yes, I agree. But the cost of railway specific equipment can be rather expensive. One typical relay for controlling a signal, a point machine or used with a track circuit can cost between £100 to £250. Some only have a service life of ten years. One conventionally signalled relay room can have between 250 to 10,000 relays (although most relays have longer service life). On schemes that use SSI modules, I believe these cost upwards of £1000 per module.
So although the day to day running costs of the staff wages is the most significant amount, the cost of (what I consider to be) routine maintenance type renewals and the cost of replacement parts to deal with failures can be significant.
Sorry - but 'defined benefit' schemes in the private sector are now unviable - this was caused in part by Robert Maxwell pillaging the MGN scheme for his own ends, which led to legislative changes that meant companies could no longer run a deficit on their pension scheme (even for a short time). The costs of eliminating such deficits would have financially crippled some large companies, hence the decision to de-risk and move to DC schemes.
The final nail in the coffin on such schemes was Gordon Brown's tax raid on pensions, particularly iniquitous that because people are *encouraged* to save into pensions by doing so on their pre-tax income, on the grounds the state gets back their tax take when people use it as their income and therefore pay income tax on it. It was doubly iniquitous, because it only affected the private sector - state sector pensions of course being underwritten by the government have no such concerns.
It would be far better if all DB schemes in the public sector were stopped - many are very generous for the amount that needs to be contributed and many (such as the police) can be claimed remarkably early. I fail to see why private sector taxpayers should be feather-bedding the pensions of public sector workers.
But that’s my point. The government needs to change the law (including the tax laws) to encourage DB pensions over all other types. All companies (that currently have to provide a pension scheme) should be encouraged (including economic encouragement) to set up and maintain a DB scheme, and new laws to provide better protection for pension scheme members should be brought in.
BTW, you do know that Network Rail does not automatically let new staff join the Railways Pension Scheme? Instead they join the Network Rail pension scheme. This has been the case for many years now.
That’s interesting about the interest payments. Ultimately though it appears that it still boils down to people costs. Regarding capital infrastructure spend, that is less of a concern as it is not apart of the cost required to operate the railways. The DfT could choose to not build any new lines or stations and the cost goes away. However capital infrastructure spend to replace existing infrastructure is more of a concern, depending upon how frequently it is required.
Unfortunately the lines between running costs and capital infrastructure spend are rather blurred. Often what was considered to be routine renewal work in the past, is now considered to be capital infrastructure spend now.
So some examples:
- The ballast is worn out under a half a mile of track resulting in wet beds, no amount of tamping (compacting the ballast under the sleepers) or stone blowing (blowing stone gravel into the voids under the sleepers) can keep the track in a good enough state to allow the line speed to be maintained. The only solution is to programme a renewal (be that a ‘ballast clean’ with tons and tons of new ballast stone) using on-track specialist ballast cleaning machines, or lifting the track and using hydraulic JCB type machines to remove the old ballast and then lay down new ballast stone. Until the work is done, a temporary speed restriction has to be imposed.
- A signal head has developed a fault that the maintenance guys cannot fix, the case is letting in rain water due to the steel having rusted away leaving it not water tight. The solution is to install a new signal head. In the meantime, the signal has to be taken out of use due to the water causing electrical issues.
Both of these affect the running of the operational railway, but both jobs will be done by the capital works section of Network Rail, not the maintenance organisation.
I agree that completely new lines (or reopening closed lines), same for stations etc. or other new infrastructure where there was different or none before (flying junctions replacing a level junction for example) is clearly completely different.
There is tremendous waste in the railway - it's there almost everywhere you look - we joke about "railway inflation" and it is a massive problem. That needs cutting even if you want to increase the subsidy for societal reasons.
It's not just the railway - the NHS, whether that bit is publically or privately operated, is riddled with it too. As to be fair are many large private businesses.
The question could I suppose be framed as "how do we make the railway better value for money for passenger and taxpayer?"
Yes, there is waste and inefficiencies. Unfortunately just cutting from the top down often does not address many of the problems that exist. Some of these problems are as a result of too much fire fighting (nothing to do with any actual fires) rather than actually putting effort and resources into sorting out the root causes. Many of the issues that the staff on the ground know about go unaddressed.
It's eliminating waste so that the money can be reinvested elsewhere in things that can deliver more value/benefit to the passenger in the future. It doesn't have to be negative...
Absolutely.
