plymothian
A collapsed culvert is causing a sinkhole to develop in the 4ft (currently 4 sleepers in length) of the up main at Newton Abbot all lines are blocked.
A 4ft hole has appeared in the 6ft near Teignmouth, believed to be a collapsed culvert. Likely to remain closed all day. Services terminating at Newton Abbot and Dawlish Warren respectively. Shuttle service operating on the Paignton branch.
CorrectThe 6 foot is the gap between the two tracks at this location yes?
Just seen that the lines are blocked. Thanks for the explanation.A collapsed culvert is causing a sinkhole to develop in the 4ft (currently 4 sleepers in length) of the up main at Newton Abbot all lines are blocked.
XC at the moment has been decimated with a significant amount of units stranded in Plymouth at the start of service.
6 or 7 Voyagers and a HST I believeA single unit being out of action on XC is significant.
How many are stuck down there?
A culvert usually carries a stream under the railway, could be brick, stone, concrete...Also a collapsed culvert is a drain?
If so what would’ve caused that to collapse, just passing trains or something else?
If it’s trains then then that’s no surprise giving the weight involved.
Does the pounding of the sea at the location do any damage?
Is it a concrete box or like road drains ie concrete pipes.
Soz but I know the principles behind drains on the highways but the railway is another matter.
It's a miracle they have been able to sort any buses at all on a Sunday in this poor weather.Not much fun at Newton Abbott. In the hour I've been in the bus queue only two buses have gone and it's not made much dent to the queue.
GWR staff on the ground here are doing a good job, and the passengers generally are in reasonable spirits.
But whoever is responsible for sourcing buses isn't doing very well.
Also a lot of companies in this area have a lot of schools work in the morning.May not be too many drivers who are sober, within drivers hours - and willing - to work on what is probably their rest day.
There is also a lot of Rail replacement work up in Bristol with a lot of the usual operators already being used up there as well.May not be too many drivers who are sober, within drivers hours - and willing - to work on what is probably their rest day.
The pictures don't do it justice either, the hole is about 15-20ft deep and 8ft in diameter at the present time.
Depending on the fix it'll either be today or tomorrow for reopening the line.My goodness, that's quite serious then. Maybe it can't be done in time for tomorrow morning then...maybe at best a temporary fix and speed restrictions but that is a substantial hole. Not looking too good.
Network Rail did a good job getting the line through the Lake District open yesterday, this looks like a greater challenge so will be interested in further updates.
The bus I ended up on came up from Truro so shows how far the call had gone out. But at the current rate of progress it's going to take a while to shift the backlog of passengers. Let's hope things can improve later as drivers sober up and so on.There is also a lot of Rail replacement work up in Bristol with a lot of the usual operators already being used up there as well.
Unfortunately for me the bus missed 12:51 from Exeter by a few minutes, and then there's a gap of an hour before the next London train. So I'll be looking at a delay of about 2 hours 40 mins.
Could be worse, but yes, let's hope some sort of repairs can be done before peak time tomorrow.
