TheKnightWho
...and of course all those container train paths - which as we know from the local RUS already prevent the second XC service being extended to Southampton.
Well exactly.
There would be no logic in 'firing up the MTUs' when 25kV AC OHLE is available. However, third rail is much more problematic due to the power supply issues present across much of the network. It seems that every major new rolling stock procurement exercise in the former NSE area requires yet more power supply upgrades, since the third rail power supply network constantly runs at capacity. If it were possible that the trains didn't need any form of diesel power at all, such as in the case of future Manchester-South Coast via Birmingham or East-West services, then there's a clear case to be made for fitting third rail shoes despite the power supply issues. If, however, you would be using a fleet of trains otherwise still equipped with enough diesel power to run happily along the relatively short extent of their routes fitted with third rail then it's not going to be that clear.
The chance of Voyagers or Meridians replacing the HSTs once they're done with ScotRail duties is tiny. The HSTs will last until the line to Aberdeen is electrified at the very least, and it wouldn't be long after that Inverness would be done as well. With that, there's no need for diesel traction whatsoever on these routes. The only remaining sticking point is Aberdeen-Inverness but with the increased passenger numbers due to the HSTs, and a need to electrify whatever suburban routes there would be around Aberdeen, I don't think it unlikely that the long term solution there would be wires as well. The Voyagers and Meridians will face the scrapheap well before stock of a similar age, simply because they are no longer fit for purpose.
I'm inclined to agree with you on the power supply issue, but remember that the DfT and NR will be looking at their fixed costs as well as their variable costs.
Power supply upgrades are a fixed cost. Once they're done they're done. Therefore of course it's a big capital outlay at the beginning, but then requires only maintenance to keep it going. That brings us onto...
Variable costs. The distance from Basingstoke to Bournemouth is around 60 miles, which is not particularly insignificant. The costs of running diesel engines down that route would obviously have a larger cost/mile (read: larger variable cost) than the cost of running the trains on a 3rd rail for that distance. NR would have to make the call as to whether the fixed cost of new power supplies plus maintenance would, over a long period, be outweighed by the cost of using engines over 3rd rail for that period.
Obviously there other costs here and there I'm not taking into account, but you see my ultimate point: which is cheaper entirely depends on how long NR expect them to be making use of that route without OHLE.
Regarding the HSTs over the 22xs: remember that the Scottish Parliament selected HSTs because they were the only trains being released that were viable. Assuming Scotland doesn't opt for entirely new trains (which would no doubt be IEPs or a derivative like the Devon/Cornwall services will get), they're more likely to opt for Voyagers/Meridians if they're up for grabs, which they may well be from XC and EMT. Better performance and cheaper to run: what's not to like? Enthusiasts not liking underfloor engines is irrelevant, really.
