GWR Dec 19 timetable
nw1
9 Aug 2013
Hi,
Saw on the recent "open access to Cardiff using class 91s" thread a proposed timetable for Paddington departures in December.
It was:
00,03,07,10*,15,18,20,25*,30,33,37,40*,45,48,50,55* (* = Heathrow Express)
Just speculating on what these might translate to, I'd guess something like:
00 - Cardiff/Swansea?
03 - Devon/Cornwall as now
07 - Bedwyn as now
15 - Additional fast Bristol via Bristol Parkway?
18 - Bristol via Bath?
20 - Oxford/Worcester as now
30 - Cardiff/Swansea?
33 - Cheltenham?
37 - Additional Newbury, fast to Reading and then all stations, using 387s?
45 - Additional fast Bristol via Bristol Parkway?
48 - Bristol via Bath?
50 - Oxford/Worcester as now
Any definitive answer on this?
II
28 Dec 2016
Hi,
Off-Peak planned to be:
00 - Bristol TM (via Bath)
03 - Plymouth or Penzance
07 - Bedwyn
15 - Bristol TM (via Parkway)
18 - Cardiff Central
20 - Oxford
30 - Bristol TM (via Bath)
33 - Cheltenham
37 - Alternate hours Exeter/Plymouth/Paignton semi-fast (IET) or Newbury fast via Reading (387)
45 - Bristol TM (via Parkway)
48 - Swansea
50 - Oxford/North Cotswolds Line
Some changes in the peaks mean generally the xx:15s run as a third train to South Wales (first stop Bristol Parkway) and the xx:45 past doesn't run but there's an extra service service to Bristol just ahead of the xx:00 Bristol's which is first stop Chippenham. Lots of other little tweaks in the peaks as well. Around twenty-five trains a day in each direction will omit Reading!
Nunners
19 Oct 2018
Do we know yet what will happen to the local Swindon-Cheltenhams as the Pads will go up to an hour? I know in the franchise spec they have to keep the ones to/from Southampton
II
28 Dec 2016
Just a down service in the morning peak, an up service in the evening peak, and two later evening down services (including the last of the day) and one later evening up service.
Paddington to Gloucester (as well as being direct hourly) will reduce to as little as 1h 42m and Cheltenham to 1h 56m.
Nunners
19 Oct 2018
Thanks
DaveHarries
12 Dec 2011
England
07 - Bedwyn
20 - Oxford
33 - Cheltenham
48 - Swansea
o_Oo_Oo_O
Golly. Out of those Bristol stoppers how many (if any) per hour will call at Didcot Parkway? Same as at present (ie. 1tph)?
Dave
II
28 Dec 2016
Pretty much the same as now off-peak, with the xx:00 Bristol calling, the xx:18 Cardiff calling, and the xx:33 Cheltenham. Only difference is the Cheltenhams are running every hour, so there's no need to stop an Oxford every other hour instead.
I13
26 Aug 2017
Do you know how much later after the 00/30 are the 15/45 meant to arrive into Temple Meads? Can't be very long.
II
28 Dec 2016
The provisional times suggest the xx:15 will generally arrive before the xx:00 by about three minutes. The xx:45 generally arrive four minutes after the xx:30.
I13
26 Aug 2017
Interesting, thanks. I wonder if the 00 will be advertised as to Bath at Paddington. What does it look like towards Paddington from Bristol - is there also overtaking?
Ianno87
3 May 2015
Doubt it - Advances would be sold on every train, plus what's the point for only 3 minutes' disbenefit? Better to spread the load across all 4 Bristol trains.
GW43125
8 Dec 2014
Apologies if I've missed something, but will there continue to be some extensions of the Bristols to Weston/Taunton/Exeter or are these being replaced by better connectivity into local services?
II
28 Dec 2016
00/23/30/53 on the way back from Temple Meads, with the 23/53 the ones routed via Parkway, so no overtaking there.
Yes, still through trains. Seven per day from Paddington to Weston with three extensions to Taunton, with one of those continuing to Exeter (the last one). Some pretty nippy running on them as well, with four of them first stop Bristol Parkway to give a journey time of around 1h 45m for one of them from Paddington to Weston-Super-Mare, even better the other way with one scheduled at 1h 42m. As long as NR can validate them of course. Table 125 is looking very impressive, less so Table 135, though that also has its moments!
I13
26 Aug 2017
Thanks. Prior to this thread I was expecting a similar spread, with the via Parkway running just before the via Bath, out of Paddington.
Anyway, looking forward to it.
HowardGWR
30 Jan 2013
Where are these timetable details available please, or are you an insider, perhaps?
CharlesR
11 Apr 2019
It’s known public knowledge from the franchise proposed December 2018 timetable that has been postponed this year. More info is probably insider knowledge.
II
28 Dec 2016
Indeed, much of it has been specified and speculated about before, but the timings I have are from 'insider' details as we approach the final stages of the timetables before they will be validated by NR (no doubt with the odd change, but hopefully not many), published and then of course implemented in December.
CharlesR
11 Apr 2019
I am certainly excited to see it finally in action after years of speculation and improvement work.
Noddy
11 Oct 2014
Any idea how long before they are likely to be published and in the public domain?
nw1
9 Aug 2013
Thanks for the info. I'm guessing the 387 to Newbury will be timed to give a self contained diagram though the turn around at both ends might be a bit tight? Or perhaps, in the hours it runs, it will interwork with the Reading Newbury stoppers?
Interesting they've gone for the clockface 00,15,30,45 all being Temple Means services even though the via-Parkway services catch up or even, in one case, overtake the via-Bath ones.
I'd have said it would make more sense for Bristol Parkway to get the 15-minute clockface, as it can be achieved without one train catching up the other too much.
Wonder if they'll still retain the xx18/xx48 peak 'fast Didcot' extras?
hwl
5 Feb 2012
I suspect the aim is almost for the Parkway ones to catch/overtake to even out loadings and encourage TM passengers to on the via Parkway services.
Flinn Reed
8 Dec 2017
I think GWR mentioned that engineering works around Bristol would enable the London-Parkway-TempleMeads services to be reduced in journey time - quoted as 1 hour 15 mins. This is as a result of doubling the tracks between Bristol Parkway and Temple Meads, with non-stop services using a separate track to the stopping services.
Is this reduced journey time likely to be implemented as part of the Dec19 timetable change?
ForTheLoveOf
7 Oct 2017
Whilst this is strictly speaking accurate, it would have been perhaps a little clearer to say "increasing to 4 the number of tracks..." - the section has had at least double track since time immemorial (well, nearly!) :)
HowardGWR
30 Jan 2013
Thanks to II for answering my query. Yes, also, it occurs to me now, by those not stopping at Reading, it evens out the loads even more, plus Bristol-bound pax don't have to out up with Reading commuters and in the other direction, airport-bound pax and their luggage.
II
28 Dec 2016
The two Paddington to Bristol TM trains per hour via Bristol Parkway (off-peak) are intended to be delivered during the validity of the December 2019 timetable, so not straight-away, but at some point by the following May.
1h 19m is the typical time from London IIRC, and a couple of minutes more the other way.
jimm
6 Apr 2012
What commuters? The extra services running to and from Bristol Temple Meads via Parkway will only operate off-peak.
The peak pattern is different - as II pointed out in post 2 and has been known for four years now and mentioned regularly on the forum since then - and although there will be one extra train per hour on the Bristol route and one on the South Wales route that will not call at Reading, everything else at those times of the day will still do so.
Bikeman78
26 Apr 2018
Why is this? Lack of train crew?
Wilts Wanderer
21 Nov 2016
It is a sensible approach in my opinion. New timetable, new train fleet, new (faster) sectional running times = performance risk. Not running the fast Bristol trains at first provides a bit of spare capacity in the fleet and some white space in the timetable to allow a bedding in period. They will be introduced as and when performance is regularly achieving sufficiently robust results that they won’t break the service.
Bikeman78
26 Apr 2018
The flip side is that they'll have to amend unit and train crew diagrams twice in quick succession. It's unlikely those extra Bristol trains will be self contained.
