Wilts Wanderer
- Joined
- 21 Nov 2016
- Messages
- 2,492
The service 2 hours behind it (1930 Padd-Weston?) also detaches at Bristol TM and that set then attaches to the 2129 Taunton-Padd on its return.
Thanks, that clears my confusion!The service 2 hours behind it (1930 Padd-Weston?) also detaches at Bristol TM and that set then attaches to the 2129 Taunton-Padd on its return.
Why should there be a problem departing from Slough? The diversions to Marylebone are only taking place on Dec 24th and 27th, and on those dates trains will be running between Bristol TM and Reading, and from the Cotswold Line to Slough, but it will be down to the diagrammers and how many HSTs are required to maintain the service.Just thinking, will the 800s be kept on depot during the christmas blockade? Pretty sure they wouldn't be cleared into Marylebone, but what about departing from Slough?
I probably worded that a bit incorrectly, what I meant was one assumes they would be fine running from a Slough start (or Reading). But then as you say it's down to diagrammers what they'd use. Just wondered if the 80x had done any off-route tests in the event of an emergency diversion. I know they sent one up to Ascot, but I wonder if that was just with horse racing specials in mind.Why should there be a problem departing from Slough? The diversions to Marylebone are only taking place on Dec 24th and 27th, and on those dates trains will be running between Bristol TM and Reading, and from the Cotswold Line to Slough, but it will be down to the diagrammers and how many HSTs are required to maintain the service.
I see 16.26 CDF PAD caped at BPW. Presumably no IET for 19.30 PAD WSM?
Hopefully we'll have an HST instead.
Could the driver not walk through the train for a bit and then get out?A potential problem at Slough would be changing ends, with a 10 car unit. The down main will take 7/8 Mk3 coaches and the up and down relief only 5 coaches. It’s not possible to change ends on the up main without a shunt. So would be fine with a 5 car unit but not so easy with a 10 car.
This was the 15:29 out of Swansea yesterday..800010+800012 - I was on this and it was 15 late leaving Swansea because one of the external doors would not close properly Did it not make it to Paddington then?I see 16.26 CDF PAD caped at BPW. Presumably no IET for 19.30 PAD WSM?
I assume the second set started OK?
I can look it up on RTT if needs be, but does anyone know off-hand what times they go off Reading (towards Padd)? Might be able to get one tomorrow if the times suit.
Do we know when the next set of IEP diagrams will be introduced?
1345 off Padd showing as delayed, notes say it is an IEP. I guess they are going to swap it in now...
Those interested in doing the Pad - Reading runs now that diagrams 3+4 have been added, here's a summary in time order:
PAD-RDG
0645 PAD-RDG 0710 (1B05) (SWA) [3]
0700 PAD-RDG 0728 (1C03) (BRI) [1]
0815 PAD-RDG 0843 (1B12) (CDF) [2]
0845 PAD-RDG 0910 (1B15) (SWA) [4]
1145 PAD-RDG 1210 (1B28) (SWA) [1]
1345 PAD-RDG 1410 (1B40) (SWA) [2]
1415 PAD-RDG 1440 (1B42) (CDF) [3]
1730 PAD-TAU 1755 (1C24) (TAU) [4]
1900 PAD-RDG 1925 (1C27) (BRI) [1]
RDG-PAD
0716 RDG-PAD 0744 (1A03) (BRI) [2]
0746 RDG-PAD 0814 (1A04) (BRI) [4]
1048 RDG-PAD 1114 (1A11) (BRI) [1]
1234 RDG-PAD 1259 (1L51) (CDF) [2]
1304 RDG-PAD 1333 (1L52) (SWA) [3]
1505 RDG-PAD 1532 (1L62) (SWA) [4]
1803 RDG-PAD 1831 (1L76) (SWA) [1]
1834 RDG-PAD 1904 (1L82) (CDF) [3]
2008 RDG-PAD 2036 (1L90) (SWA) [2]
0029 RDG-PAD 0105 (1A37) (TAU) [4]
I've included headcode and origin/destination, and the numbers in square brackets are the diagram numbers in the order they're presented in the OP.
There is a separate thread for weekend diagrams, but for this weekend so far it is not clear.Are there likely to be some IETs out this Sunday? (Just thinking about a Staines avoidance move)
Appears you're right! Thanks, have amended. I was going by OP and appears they missed that one off.Many thanks, isn't the 19:30 Western service an IET (Diagram 3?)
