Handheld 'S' Car Stop Marker
jnjkerbin
25 Apr 2012
Down south
At Tonbridge Platform 1, when the Redhill and Strood services are to share the platform, a member of platform staff will signal the arrival from Redhill to stop in the correct position using a handheld 'S' Car Stop marker - the same size and shape as a dispatch bat, but with a white-on-blue 'S', like a car stop marker.
Is this a standard signal, or something peculiar to Tonbridge? I can't recall ever seeing one used elsewhere.
ComUtoR
13 Dec 2013
I've seen it used elsewhere so its not specific to Tonbridge.
Ashley Hill
8 Dec 2019
The West Country
In the past I’ve seen this done by the platform staff just holding out their arm. Drivers having understood it meaning “stop here”.
ARIC
7 Mar 2019
At Manchester Victoria they hold out their dispatch bat
Undiscovered
28 Jan 2013
Two of the stations I sign and they use hand lamps and hand signals to call trains down
The smaller station has the clip handle to turn the hand lamp into a shunting lamp.
i4n
30 Apr 2018
I've seen that in use at Dover as well.
As I understand it, it is a handheld version of the "S" stopping location board so in the case I saw it in use, they stopped a train coming in from the Folkestone direction earlier than it would normally have stopped (at the 4 carriage marker) so that another train coming from the Canterbury direction could also get into the platform and they then joined them together.
ComUtoR
13 Dec 2013
It's worth noting that the Driver may completely ignore it and drive past.
