johncrossley
So, I'm just on my way back from a business trip to Glasgow and Ayrshire. Whilst there I hired a BMW i3 from a car club for the princely sum of £38/day.
That sounds amazing. Have you got a link to this?
Better fuel consumption and reduced brake wear, so less particulates from brake dust and longer life of pads and disks.
www.co-wheels.org.ukThat sounds amazing. Have you got a link to this?
That could be an effective solution to the problem.Charge per minute that the charger is used and base this calculation on when the cable is out of its holder. As long as this was clearly communicated, people would soon realise that they need to re-seat the cable before driving off! You could set up some kind of system where the driver gets a text alert once the car stops drawing power.
(In fact, ideally, let some people get caught out by it and then refund their money as a goodwill gesture to great fanfare in the press).
The post I responded to was referring to regular hybrids, not plug-ins.The key advantage of a PHEV (plugin hybrid) is that it can run on electricity where particulate emissions cause most harm, i.e. short journeys in towns.
Alternatively could some device which acts as both an EV charging station and a lamp post be designed? I suspect it could.
https://www.ubitricity.com/ - Already exists along with other solutionsThey'd have to be smaller than the current public chargers that are being installed, both to avoid taking up large amounts of pavement space and to keep the NIMBYs at bay.
Zipcar: Car Sharing Alternative for Daily and Hourly Car Rental
Zipcar is the world’s leading car sharing alternative to car rental & ownership. Book cars on demand by the hour or day. Join instantly, drive in minutes.www.zipcar.com
Indeed. I am somewhat puzzled by the obsession with having a fast charger at home. My neighbour recently started renting a Leaf, and went to pretty extravagent expense putting in concrete ducting and armoured cable to a new rapid charger he had installed on his drive. He was showing it off to me, and I asked "But why not just plug it into the 13A socket that was already on the outside wall of your garage [like many, the garage is used to store "stuff" not cars]?"No problem with them being smaller; outside houses they would not need to be fast chargers, 13A would be fine.
I do think it's worth having something specific put in. Particularly in a house with old wiring! But fast chargers aren't exactly required. Just a well installed, on a new wire, 13A socket should do the trick.
I agree. On older housing estates it is surely also the cables and infrastructure leading up to the house too?I do think it's worth having something specific put in. Particularly in a house with old wiring! But fast chargers aren't exactly required. Just a well installed, on a new wire, 13A socket should do the trick.
In reality a standard 7kW wallbox with a type 2 cable is the best simple solution, it runs off a simple 32A spur. This charges at 21 mph versus a 13A socket at 6 mph. Why? So A - you can charge in the cheap slots, usually just 4 hours and B you can charge for longer commutes easily. Being able to add 60 miles overnight versus 250 miles is a no brainer and allows quick top ups when needed.Indeed. I am somewhat puzzled by the obsession with having a fast charger at home. My neighbour recently started renting a Leaf, and went to pretty extravagent expense putting in concrete ducting and armoured cable to a new rapid charger he had installed on his drive. He was showing it off to me, and I asked "But why not just plug it into the 13A socket that was already on the outside wall of your garage [like many, the garage is used to store "stuff" not cars]?"
He looked slightly horrified at the suggestion and said "Ugh, that would take ALL NIGHT to charge up! With this I can fully charge it from zero to 100% in about an hour!"
I said "So what? When are you ever going to arrive home with a nearly flat battery and almost immediately need to go straight back out on a long journey?". He went a bit quiet at that point.
The real irony is he hardly ever uses the car, preferring his wife's diesel BMW. I suspect that's because he gets a ludicrously small mileage allowance on the Leaf (he was also boasting about how little the monthly lease cost is).
When I get an EV I'll just have an external 13A socket put on the outside of the house. Don't really see the need for anything more than that TBH.
In reality a 7kW charger tends to be essential. a 2kW granny lead will do some of the time but have a reputation of melting substandard wiring.There is a spec for a 13A charging socket intended to have a full 13A drawn from it for a long period, one of these can be installed, as you say on a separate spur to the consumer unit as per e.g. a shower.
You definitely shouldn't use a double socket as these are not specced for 2 x 13A!
But either way you don't need a fast charger for at-home charging. On the rare occasion that you might have two long journeys back to back, pop out for lunch somewhere with a fast charger.
Most cables to houses are rated for 100A, this has long been the standard. If it is so old not to be able to deliver this it's time the DNO replaced it TBH.I agree. On older housing estates it is surely also the cables and infrastructure leading up to the house too?
100% (pretty much) of ICE users use remote filling stations for every recharge of their cars. Are you making the same 100% assumption about EV drivers? If so then that would be flawed.....if our present petrol pump can fill us up in 5 minutes say, every motorway service station will need 30/5
A hybrid has all the dis-benefits of both tech but little of the benefits.
That's one of the reasons that I changed to a PHEV when I retired. I'm happy to do short trips to vary the start points of my daily walks, to get heavier shopping, etc. I wouldn't have wanted to do such trips in my previous 2 litre diesel which took 10 - 15 minutes to warm up. Its particulate filter wouldn't have liked them either.
My local Sainsbury's offers free charging, so around a half hour shop there gives me (almost*) free travel there and back.
It's also very low-stress to drive, no clutch or gear changing needed (although you can change gear manually when running on petrol), and of course no engine noise on local use.
*Obviously there is some added tyre wear etc.
The better fuel consumption point doesn’t always apply. I’ve mentioned it numerous times but if I were to swap to a 330e I’d be no better off than I am in my current petrol engined car and actually worse off than in my previous 520d. I appreciate that I’m talking about my own circumstances here, I’m not claiming this is a general rule although I imagine it will apply to plenty of other people.
You may be correct in regard to particulates from braking, but the extra weight of a hybrid detracts from some of the advantages. To what extent are these particulates considered a problem out of interest?
I read an article last year about a study which estimated that following far stricter emissions controls the past 10-15 years, brake dust now accounts for a greater volume of airborne particulates than exhaust emissions in urban areas, can't remember where I read it unfortunately.You may be correct in regard to particulates from braking, but the extra weight of a hybrid detracts from some of the advantages. To what extent are these particulates considered a problem out of interest?
It is estimated that 90% of users charge at home 90% of the time.100% (pretty much) of ICE users use remote filling stations for every recharge of their cars. Are you making the same 100% assumption about EV drivers? If so then that would be flawed.
When I ordered it nearly two years ago, I was still doing relatively frequent long journeys, from south east England to the west country, Wales or Scotland, and I wasn't sufficiently confident in the charging infrastructure to go full EV. There was also a rather smaller range of "normal car" EVs available then - I don't want to drive an imitation 4x4.As above; they have their place but would you not be better off with a full EV? Obviously I don’t know the nature of the other journeys you make.
Particulates are a very topical issue if you're in urban environments! This post and this post in a different thread gives some helpful context about how severe an issue it is (though losing a couple of months of life is small fry compared to the environment being generally much more pleasant - compare the air in a small town to london and you'll see the effect!)
It's surprising perhaps that the 330e would give you worst mileage than your current car (given your current one is quite sporty IIRC? Not even Ford can overcome the laws of thermodynamics) though I suppose it implies your use case is a lot of longer journeys where the weight (and generally larger size) works against the hybrid. I'm still disappointed that we didn't see more diesel PHEVS which (bar weight) would have been the ideal vehicle - EV in urban areas and low CO2 diesel on interurban where the NOx and PM don't matter as much
You mean the BMW 330e, thought that was only available as a Plug-in Hybrid? I'm guessing it's optimised for performance rather than economy.
My baseline is my Niro Hybrid which typically achieves 60-65mpg around town and on country roads (pretty sure no ICE car can match that, definitely not one of comparable size), dropping to 55-60 for motorway driving, still better than virtually all petrol cars but bettered by some diesels.
That of course depends on your typical driving ‘cycle’. As I’ve said before, a good friend of mine has a 330e, uses it to get to work 15 miles away, and various other trips of a similar distance. He rarely has to put fuel in at all. To all intents and purposes, for him, it’s an EV with an engine bolted on.
Back to on street charging, here is a lamppost charger near Euston...
Obviously I've done fewer long trips than I expected, and I might choose differently today, but I plan to get quite a few more years out of the PHEV first!
The issue with that however is that a lot if cars are considerably less efficient charging on 13A compared to higher currents. It also makes it very difficult to charge only on cheap EV time-of-use tariffs, unless you're only doing tiny mileage. For rare use a 13A socket is a good solution, but for most people a dedicated 7kW charger is useful.Exactly. The use-case for home charging is for the car to be plugged in whenever you are home, which is the majority of the time, meaning you almost always go out full. 13A is absolutely fine for that, and if people do just use 13A mostly overnight the impact on the grid is no worse (indeed, quite a bit better) than if they'd all just fitted storage heaters.
If many people take this view then yes, EVs will be to the detriment of walking and cycling. EVs are too big, too heavy and use too much energy to be used as raincoats.In addition to this, some drivers such as myself avoid very short trips as they don’t do the vehicle a lot of good and they are highly inefficient as the engine doesn’t get up to normal operating temperature (these aren’t the only reasons I hasten to add!). Neither is an issue with an EV so a two minute trip to the corner shop etc. is as good as “free” and I’m sure some people will take advantage.
Will EV users ride trains and buses more or less than before?
I can answer that as a 6 year EV driver.If many people take this view then yes, EVs will be to the detriment of walking and cycling. EVs are too big, too heavy and use too much energy to be used as raincoats.
Not currently an EV owner but my next car will definitely be one. I don't think it will make the slightest difference which mode of transport I use, my choice is currently and will continue to be driven by speed, practicality and convenience.Will EV users ride trains and buses more or less than before?
Not cost at all?Not currently an EV owner but my next car will definitely be one. I don't think it would make the slightest difference which mode of transport I use, my choice is currently and will continue to be driven by speed, practicality and convenience.
