bluegoblin7
In contrast I travelled earlier Rickmansworth to Kings Cross on the Met - all fine , bar the fact that off peak the fast lines from Croxley Jct are not used with the result everything on the slow lines blocks back and crawls- such that my train was terminated short at Moorgate. Odd way to run a 4 track railway with nothing wrong.
I’m not at work today so I don’t know for certain, but I would assume that the Harrow Hot Weather Plan was in place - there is a set of points north of Harrow that, quite simply, doesn’t like the heat, and are known to fail. When rail temperatures rise alternative plans are put in place to protect overall service resilience, and prevent the junction from failing. Similar things happen on NR AIUI. This also protects the Chiltern service, but means that southbound fast services have to run down the Local line as opposed to the Main (not fast/slow in this area).
Whilst this does have the result of requiring some services to be short-tripped, it guarantees overall resilience. Peak flows are all west/north of Moorgate on the Met.
TFL in there wisdom decided a few years back that passengers wouldn't understand a mix of fast and all stations trains on the met hence all slow off peak, same reasoning results in most cases buses have to run the full length of the route all day even if the demand isn't equal throughout the route.
Actually with the Met line the issue is not with the variety of stopping patterns, but about increasing capacity south of Moor Park. The difference in journey times is negligible.
