• Dear Guest, and welcome to RailUK Forums. Our non-railway discussion forums are currently restricted until members have five or more posts, and you will not be able to make a new thread or reply to an existing one in this section until you have made five or more posts elsewhere on the forum.
Help, I can't get back from Mobi theme to a normal theme!
Techniquest
19 Jun 2005
Nowhere Heath
Can't see where else to put this, so here goes:
I chose to use the Mobi theme for the forum recently-ish and then discovered the mobile app. Problem is that I can't find a way of changing back to the normal theme for use on the laptop.
Anyone able to direct me to the relevant bit? Looked all over User CP in this theme and cannot find the option to get off this annoying theme!
Class172
Quizmaster
20 Mar 2011
West Country
Maybe there should be a link on the mobi theme to reset the theme to the default.
Techniquest
19 Jun 2005
Nowhere Heath
Badger: So very much appreciated, I can finally go back to viewing the forum in the manner that I'm used to! Thank you very much indeed! :D
