Help!! North camp to Wembley Central route
ciderbilly
27 Aug 2012
Hello.
I have just boughta North camp to Wembley central ticket ( not valid via london terminals although didnt say that till printed) ticket from the machine and need to get to Wembley and currently on the train to Reading. Any ideas how i complete my journey without actually going to a terminal. I think my options are Waterloo and Paddington both invalid with this ticket. Im stumped.
12 Dec 2018
At a guess i'd assume the ticket is intended for journeys where from reading, you take a waterloo train as far as richmond, change to overground round to Wilsden junction, then down the dc lines to wembley.
ciderbilly
27 Aug 2012
Thanks for help pal. I approached the ticket inspector and paid a excess fee to allow me to go to Paddington. He couldn't offer any valid routes.
I suspect the idea is that you are supposed to use either SWR to Clapham Junction and then the West London Line Overground or Southern services, or GWR to Wokingham changing to SWR to Richmond, then North London Line changing at Willesden Jn.
Note that for many suggested routes National Rail enquires starts with a walk from North Camp to Ash Vale on the Waterloo via Woking line. Starting with a walk seems to generate a lot of debate...
I’m not at all sure if “via Reading” is a valid route for that ticket (as you have now found onboard the train) - others will know better.
ForTheLoveOf
7 Oct 2017
The intended use of this ticket is to avoid London, going via Guildford or Ash Vale, and then via Clapham Junction, Kensington Olympia and Willesden Junction.
The guard was very much in the wrong if they suggested that there were no valid routes and therefore you had to pay an additional fare. It is fundamentally not permissible to sell a ticket for one price and then to say that you need to pay an additional fare to actually use it!
If, of course, what he meant is that if you wanted to continue along the route you were using that you needed to pay an additional fare, then this was correct - if you were indeed following a route otherwise than that which you selected when buying the ticket.
MarlowDonkey
4 Apr 2013
You could take the GWR stopper from Reading to Ealing, Central Line to Shepherds Bush and then the West London line service to Wembley. Probably still not a valid route.
ForTheLoveOf
7 Oct 2017
Nope, not a permitted route. and most problematically of all you'd be liable to a Penalty Fare if caught whilst on the Underground leg as the ticket has no Underground validity whatsoever.
kieron
22 Mar 2012
Connah's Quay
It can do, but shouldn't do in this situation. Ash Vale is a valid routeing point for North Camp on a North Camp-Wembley Central ticket. This means that a ticket gives you the right to catch three trains to get to North Camp and continue from there without any walking. As there is no break of journey restriction on any of the tickets offered for the journey, missing out those trains to start your rail journey at Ash Vale is also permitted.
I know there is a line in the routeing guide that says that any routeing point which doesn't have a direct train from a station associated with it should be ignored, but I don't think it's a very practical idea, and the web sites I've tried don't seem to take account of it.
I took the original poster’s point to mean that the inspector (or guard?) on the train to Reading couldn’t find an onward route from Reading along the GWML that wouldn’t involve Paddington and/or London Underground, neither of which would be permitted for the original not via London ticket without a “Maltese Cross”.
It can do, but shouldn't do in this situation. Ash Vale is a valid routeing point for North Camp on a North Camp-Wembley Central ticket. This means that a ticket gives you the right to catch three trains to get to North Camp and continue from there without any walking. As there is no break of journey restriction on any of the tickets offered for the journey, missing out those trains to start your rail journey at Ash Vale is also permitted...
Isn’t the practical explanation in this case that, given a choice of stations in the vicinity of his origin, the OP made the wrong choice? Obviously there’s nothing to tell you about this on a TVM of course. Perhaps the ticket he bought should display a different “Routeing”, as going via Reading effectively leads you to a dead end.
Hello.
Once on the train to Reading, you could have changed at Wokingham & Clapham Junction (also to change at Richmond/Willesden Jn, but this is slower)
But it would have been faster to take a train to Farnborough North, walk to Main, then go non-stop to Clapham Junction.
Or even faster would be to walk to Ash Vale and take a train to Clapham Jn from there (note: if doing that, it's cheaper to buy a ticket from Ash Vale to Surbiton and another from Surbiton to Wembley Central).
At Clapham Junction, if there is a train to Willesden Jn before the next Wembley Central direct, it's generally quicker to change at Willesden Jn.
30907
NRE gives routes via Wokingham and Richmond, Guildford Clapham Jn and Richmond, as well as the walk to Ash Vale. The Kensington route doesnt show for some reason.
No via London terminals routes show so must always be slower (at least in theory).
NRE gives routes via Wokingham and Richmond, Guildford Clapham Jn and Richmond, as well as the walk to Ash Vale. The Kensington route doesnt show for some reason..
Today? That'll be due to engineering works. The fastest journeys tomorrow are via Kensington Olympia.
30907
That's what I guessed but didnt have time to check. And Reading-Paddington-Bakerloo does show up on a Saturday even if it's not the quickest.
If the GW guard was on the North Downs line, then it's poor that they couldn't find an alternative route, but it will depend on how the conversation went.
And it's unfortunate that the OP didn't check which way he should leave North Camp, given the options.
nuts & bolts
24 Jan 2015
B & H
Don't blame the Guard he was giving correct travel advice!
There was no Overground services on Sat 06 & 07 July from Clapham Jct to Willesden Jct and elsewhere on their network due to booked engineering schedule.
It was, however, possible to change at Richmond.
If the conversation took place before Wokingham, then it would have been perfectly valid to change at Wokingham, Richmond and Willesden Jn without paying the excess.
If the train had already departed Wokingham then it would be correct to issue the excess fare.
nuts & bolts
24 Jan 2015
B & H
But as in my original response to post #5 there is supposition that the Guard was not offering correct advice, as the OP stated very briefly he got his ticket excessed from a ticket inspector, job done.
Let's not speculate If railway staff are not correctly carrying out their duties.
There have been no services from Richmond Overground this weekend, again to booked engineering work - as previously mentioned.
We can only go by the information posted; we were told "Thanks for help pal. I approached the ticket inspector and paid a excess fee to allow me to go to Paddington. He couldn't offer any valid routes." so I stand by what I said in post #16.
Did this train not run: http://www.realtimetrains.co.uk/train/L66910/2019/07/06/advanced ?
nuts & bolts
24 Jan 2015
B & H
We can only go by the in formation to hand!
I see where you are coming from, but the 'passenger train alteration notices' include the following engineering works info to supplied to TOC staff as here:
TFL Engineering Works
Line Date
London Overground
Saturday 6th & Sunday 7th July Willesden Junction to Clapham Junction
Surrey Quays to Clapham Junction
Liverpool Street to Enfield Town, Cheshunt via
Seven Sisters & Chingford
TfL Rail/ Elizabeth Line Saturday 6th July Liverpool Street to Stratford
Information correct at time of going to print. Please check the website below for up to date details:
http://www.tfl.gov.uk/tfl/livetravelnews/realtime/tube/default.html
Line Date
London Overground
That doesn't mention the Richmond to Stratford service, and journey planners were giving itineraries.
causton
4 Aug 2010
Nothing like bashing a member of railway staff for being helpful and actually giving the customer what they probably wanted in the first place... let's find a technicality to complain about them and put a claim in :lol:
nuts & bolts
24 Jan 2015
B & H
I hold my hands up - I lost the plot and went off on a tangeant, Richmond just got stuck up in the grey area for a while.
MarlowDonkey
4 Apr 2013
If you really wanted to use the route via Ealing Broadway, I suppose it would have to be a split ticket. National Rail to Ealing Broadway and Oyster/contactless beyond.
ciderbilly
27 Aug 2012
Thanks for the overwhelming response.
The gaurd was most helpful but just couldn't find a route and to save a lot of hassle and make the journey a lot easier i paid the couple of quid excess on his recommendation and went via Paddington.
