Heritage Railways and Headcodes
XCTurbostar
13 Sep 2014
Do Heritage Railways use headcodes for all their services or are these usually only used for services leaving towards the national rail network?
Thanks,
Thanks,
If you mean 4-character codes used internally on working timetables etc, I think the G&WR do.
If you mean lamp or disc codes as used on steam locos, I would expect them to be used appropriately - though whether a non-stopping train travelling at 25mph max should count as an express is a moot point :) .
XCTurbostar
13 Sep 2014
Thanks 30907, I do mean the 4-character codes. My thinking was whether the same rules which govern them to 25 MPH max also govern their use of headcode train identifiers. This might be of particular importance if the RAIB was investigating an incident etc.
John Webb
5 Jun 2010
St Albans
The North Yorkshire Moors Railway's through trains to Whitby are given 4-digit headcodes to identify them on the national network and appear on sites like Real Time Trains. But the internal Grosmont-Pickering trains are not identified in this way. Even RAIB's Digest on the low-speed collision at Grosmont in September last year involving a Whitby-bound train from the NYRM did not bother using the allocated number!
xotGD
4 Feb 2017
Often when you look at the timetables for diesel galas they include a headcode for each service. Whether these are used by the railway or just there to keep the cranks happy is another question.
Bertie the bus
15 Aug 2014
You have completely lost me. How could using a headcode be of any significance to an incident RAIB might investigate?
Certain heritage railways certainly allocate headcodes to trains during diesel galas but that is more playing to the crowd than performing a function.
Bristol
Thanks,
Some heritage railways will use old standards of train classification to signal the trains according to their rulebook, and may use 4-Lamp or 6-Disc codes correctly or not depending on their policies, etc. Some railway like to be more 'correct' whereas other just want to give a feel for old-fashioned practices. I think the Bluebell and Mid-Hants use (or have used) the old RCH Class A-H bell codes for signalling, but am open to correction. When they display 4-Digit Train IDs on the front it's usually just for show, some railways may allocate actual numbers but very few are published in an obvious way.
All trains running between Network Rail and a heritage railway require a 4-digit Train ID to have a schedule entered in TRUST. If there's no schedule in TRUST, then it won't go onto NR.
a340egkk
22 Feb 2017
The railway I volunteer at, we use *X** headcodes for all of our services, although these are not displayed on the train. Lamps & discs are not used for train identification purposes.
Tomnick
10 Jun 2005
No. The primary concern will be around identifying trains for the purpose of safety-critical comms, and it's a matter for each railway to assess and manage that risk. Clearly a basic "one engine in steam" operation has much less to worry about in that respect, but even where there's a clear need to have a system of identification, it doesn't have to follow the four-character system.
Richard Scott
International Transport
Railtours & Preservation
13 Dec 2018
They definitely are used and have to be quoted when communicating with signalman etc.
william.martin
18 Oct 2022
Telford
Headcodes are used on the SVR
43106 with a headcode board at Kidderminster last year
Not sure if headcode "board" is the correct word, apologies if it isn't
30907
Looks like a train or loco duty number - a rectangular version of the old SR disc that carried the loco duty. Was it a special weekend?
kje7812
1 May 2018
York or Kidderminster
On the SVR, any headcode numbers are just for show. There aren't used in the operating notes, with the exception of a couple of diesel galas from memory.
The lamp codes are used though.
