How did Class 360s get their speed uprated from 100mph to 110mph maximum?
Is shoegear out of gague in non DC areas. Isnt that why cl73 had retractable shoegear? So how did that work north of Drayton Pk?
it’s kept clear, as is everywhere where Dc units run off the DC (MML, ECML, WCML, NLL, etc)
Domh245
6 Apr 2013
nowhere
How, when many units have shoes on fixed beams that are not retractable?
By keeping the area which would have third rail in it clear of ballast and any other obstructions? ISTR that a few areas on the ECML were found to have high-piled ballast when the 700s first ventured out and came back shoe-less
507020
23 May 2021
Southport
So the infrastructure must be kept clear where the third rail would be to avoid damage to the shoes, not the other way around. I assume this is the difference between W6 and W6a gauge then.
AM9
13 May 2014
St Albans
I think it's simple to imagine the same gauge found on 3rd rail lines without the 3rd rail there. On a 3rd rail line, there wouldn't (or shouldn't) be ballast and other detritis heaped up to the bottom of the live conductor rail, so consider that.
Ken H
11 Nov 2018
N Yorks
What about point motors and stuff like that?
507020
23 May 2021
Southport
I am of course most familiar with 3rd rail lines with my local line being one. I thought it meant keeping the shoes clear of where the 3rd rail should be, which isn’t exactly possible on a fixed beam.
aleggatta
28 Sep 2015
the difference might be that vehicles are kept clear of where the third rail is in W6a (thinking something about Mk 3 coaches operating over DC lines and having different suspension components?) to prevent arcing etc. A look at the two guage standards would probably be prudent
Magdalia
1 Jan 2022
The Fens
The first class 700 to Cambridge lost shoes between Royston and Cambridge.
Class 313s were only permitted between Royston and Cambridge if the shoes had been removed.
AM9
13 May 2014
St Albans
There is a lower level that the shoe will not go below, (i.e. about half of the conductor rail depth shown as where it hits that ramps). So any obstruction above that level on track where there isn't a 3rd rail would potentially catch on a shoe. For occasional passage of non-raising shoe stock, (e.g. on a visit to Wolverton works) the shoes would be removed. If there was to be a service using non-raising shoe stock, the track would need the clearance to be complete and maintained.
And the first 319 to Rugby ditto!
507020
23 May 2021
Southport
Does this clearance exclude the shoes, for obvious reasons?
Had the last DC stock that Thameslink sent that way been a 387 with retractible shoes by any chance?
AM9
13 May 2014
St Albans
Probably, it looks like it was an oversight.
There seems to ba a lot of labouring this issue here. On non 3rd-rail routes, ballast and other rail level obstructions are cleared to comply with the W6 gauge. On 3rd rail routes, the requirement is that to meet the W6a profile, specific attention is required to clear to a slightly lower level so that collector shoes do not get fouled. It seems that most of the incidents of shoe loss are when 3rd rail stock that has non-retractable collector shoes is sent over routes that haveen't been specificallly cleared to W6a standards. Probably the most likely cause is when stock is sent to maintenance centres or other irregular diagrams over mainline routes where ballast has been generously laid in order to improve the track resilience to high speed running, notable the WCML and the GWR lines come to mind. I'm sure that there are others. As far as point motors etc., are concerned, I imagine that it would be pretty old installations that have motors that impinge on the W6a profile, so maybe less likely to occur on a trunk route. Maybe a track expert here could comment.
The opposite situation is also catered for where normal rolling stock may need to modified to rum over 3rd rail routes, the one that I can think of is the MKIII LHCS where short link arms on the bogies were required to limit movement of components to clear the conductor rail. It was also designed into the class 442 EMUs* form the outset, which of course lived on the 3rd rail network.
* I claim the first relevant mention of class 442s in this thread. :)
A shoe striking a point machine could lead to movement of the points and derailment of the train (remember Ealing Broadway 1973ish?). However I would expect the machine itself to be far enough from the rails not to be at risk from shoegear impact, and the actuating bars to be too low down.
Razorblades
17 Dec 2021
Sutton Coldfield, West Midlands
Yes, 19th December '73. Class 52 Western Talisman's battery box door opened/ deployed into its lowered position and behaved as a perfect point machine actuator.
AM9
13 May 2014
St Albans
Which has nothing to do with collector shoes on EMUs running on non-3rd rail track. This thread really has gone a long way from the original subject.
