Locally in Bucks the displays on town centre bus stops are regarded as a joke. Sometimes buses aren't shown, sometimes the time to arrival will drop by 15 or 20 minutes in one go. The errors aren't consistent so I can't put it down to an error in how the routes and times have been entered.
Since discovering the real time map on bustimes.org I have checked this against the time and found that they are pretty accurate about the location of the buses. I have found, however, buses showing on the map with the wrong route number or supposedly travelling to the terminus that they are heading away from. The latter instance was the bus that I was waiting for and there was no countdown showing at the stop.
Is the local authority's system simply wrong or are they using a source other than the accurate GPS readings that bustimes have?
I am guessing that issues over buses going the "wrong way" are down to drivers not resetting route displays properly. The worst offending route terminates in loops at both ends so there is no obvious point where you can say that the outbound trip has finished and the inbound started.
