GRALISTAIR
Now that a Climate Emergency Declared how do you think it will affect railway policy?
Government U turn when faced with a backlash following the crash in property values for flats and terraced houses as the inability to charge an EV effectively bans residents from owning their own vehicles.
Had not thought about that - said tongue in cheek - but a totally legitimate concern for those without driveways.If I park on the street at night, and I can’t always park outside my house, how do I charge the car... @GRALISTAIR this could be another meaning for the Great Extension Lead
If I park on the street at night, and I can’t always park outside my house, how do I charge the car.QUOTE]
Km
We all know that fuel use inflates exponentially with increased speed, so impose a national speed restriction of 80 mph on all routes.
Would also save a fortune in infrastructure costs
restrict them to 60 (or maybe 50 like we did during the 1970's oil crisis)Thought you meant for motorways!
What might happen:It might see any or all of the following:
- Severe restrictions on air travel leading to an increase in long-distance train travel. Won’t happen
- Severe restrictions on private motoring leading to a general increase in train usage. Won’t happen
- Severe restrictions on road freight transport leading to an increase in rail freight. Won’t happen, indeed couldn’t happen. Different markets largely.
trains are basically a tube with seats in it, holes for windows and some traction guff underneath. you can change a train by replacing the traction guff. South Western did that to avoid having to build a new depot as the new traction stuff regenerated so the brake pads didnt wear out so fast.Perhaps one way could be all railway stock over a certain age is scrapped due to relatively uneconomical fuel consumption (diesel or electric). The scrap metal/other parts are recycled in such a way that they feature in future modern rolling stock (to avoid energy use associated with brand new raw materials) with greater energy efficiency, which does the obvious for diesel, and even for electric the railway leads to less use or more potential for same energy use
While I see your point here, I did also read in the Scotrail HST introduction thread about Mk3s not being in good condition structurally, so if the train bodies cannot be effectively "patched up" recycling them via scrap will have to happen.trains are basically a tube with seats in it, holes for windows and some traction guff underneath. you can change a train by replacing the traction guff. South Western did that to avoid having to build a new depot as the new traction stuff regenerated so the brake pads didnt wear out so fast.
The 165's were designed to be converted to EMU if GW electrification happened.
Lets advocate retractioning, not replacing the whole train.
Maybe Northern should re-traction the 319's??
They are mild steel. they can have bits welded on to make them sound again.While I see your point here, I did also read in the Scotrail HST introduction thread about Mk3s not being in good condition structurally, so if the train bodies cannot be effectively "patched up" recycling them via scrap will have to happen.
Not sure on that - further trials were included in the new MML franchiseHydrogen hybrids for passenge4 trains shown to be a non starter.
No need for a 'climate emergency' for that to happen...further electrification on the busiest / higher speed lines. Mid 2020 - Mid 2030s.
No need for hydrogen hybrid. Just hydrogen.
It's on its way.
Never said it was.Not doable for freight.
Indeed, the NIC have recently suggested that all railfreight could be transferred to non polluting road HGVs to save the cost and disruption of further electrification!Not doable for freight.
