Nottingham59
If it's any interest, this is what i thought the specification should be for a network-wide regional express BEMU:I'd be interested to see what batteries they are using for the German BEMU. I'd guess that if they are not using the top 20% it's an NMC type which is what most long range BEV cars use.
Power storage and transit vehicles are likely to use LFP types which have a higher cyclic life and also don't mind bring charged to 100% (at the cost of ultimate energy density). Though the other reason not to charge to 100% is that the charge rate is super slow for 90-100%, it's fine for a BEV where max range trips are rare, less good for a public transport vehicle.
Regarding range, I'll have a look in the IET specs they did have some other routes with expected energy usage, but I'm pretty sure the energy usages for all the InterCity routes were pretty similar with stops offsetting higher cruising speeds.
The other key bit about the ultimate potential for BEMUs is to look at what they are doing with cars, it now possible to put extreme levels of performance into mundane cars at minimal marginal cost. Our class800X train with it 2.2MWh battery (Around $250k at current prices) will be able to discharge that battery at 5-6C for a few minutes. Which means that our 250 tonne 5 car train could have 14,500-17,500 horsepower!
The Tesla Model S Plaid motor drive unit is 90kg for motor, inverter and gearbox, if we put 2 of them on every axle (like in the car) we'd have a matching 17,000bhp. Those drive units also cost in the region of $2500 so about $100k of drive units for the train or a pretty trivial price. (the arguments about relative duty cycle between the train and car also go out the window as this thing won't spend very long at high power) The reason they can do this is because, in a single year some of the larger EV manufacturers are turning out more traction motors than the whole rail industry has ever used!
So on out class 800x we would now have the capability to accelerate at the traction limit (say 1.3m/s/s) up to about 80mph and then on to 125mph in 50 seconds. Widely replicated I'd suggest this might do wonders for capacity and journey times. I shudder to think what the infrastructure costs of upgrading electrification to allow every train to put out 3-4 times the power output of a typical EMU, ergo I think the argument may well be that every EMU ends up being a BEMU because it allows higher performance on the same infrastructure and using components sourced from the rapidly expanding automotive supply chain means there is negligible cost for doing this.
Design for a universal Battery EMU for the GB rail network
What should be specification be for a national fleet of Battery EMU's to decarbonise the GB rail network? It seems to me there is a need for Battery EMU's now, which can be deployed the many routes where there are currently diesels running under the wires. As electrification progresses, this...
www.railforums.co.uk
