I’ve been wondering, could driverless cars begin life as part of a PRT-like system but using public roads rather than a segregated guideway network?
The Morgantown system is intriguing in that it allows point to point, turn-up-and-go travel without the need for a driver, but is only achievable because it uses a segregated guideway. Now that autonomous vehicles are more likely to become reality, I suggested that a segregated PRT-like system could work for AVs using a normal road surface rather than guideway, but as others have pointed out it would have the disadvantage of not being able to provide door-to-door travel for everywhere, which is one of the main objectives of AVs. Having thought about this further though, could a non-segregated version of a PRT work using autonomous road vehicles in areas of low traffic?
I say low traffic because as mentioned before, introducing AVs to areas of high traffic density will likely cause problems until technology improves vastly to the point that AVs are 100% fail-safe and foolproof. I think they would be better off as a replacement for rural demand-responsive transport, with separate networks using accessible pod-like vehicles to provide travel between a cluster of rural villages and their nearest market town or railway station. These vehicles would travel along the quietest roads wherever possible so as to reduce conflicts with other traffic.
The removal of drivers from the equation brings two advantages over existing DRT. Firstly, costs are reduced so more vehicles can be provided which in turn allows each user/group to have a vehicle to themselves, and secondly bookings can be made for any journey at any time, rather than having a booking deadline on the day before one is due to travel. Both of these would bring DRT more in line with a conventional taxi service, albeit without a driver present so you could argue that it is actually a PRT using public roads rather than a guideway system.
While this would be a godsend for rural areas without any alternative form of public transport, I don’t think it would be workable in urban areas or those which already have a commercially viable bus service. I say this because if you started to introduce driverless DRT to those areas, passengers would be abstracted from existing transport in the area, and the personal nature of this concept means you would have to provide more vehicles, bumping up costs and increasing congestion in the process. It would then become a disaster if manually driven vehicles still existed in those areas, hence why I suggest that fully driverless cars should stick to rural areas and controlled-access roads during the early stages of life.
