Surely encouraging people off the road and onto the rails is a good thing.
But doth not a Business Case make (unless in very, very significant quantity), especially if effectively cross-subsidised.
There's lots of locations which are impacted, for the simple reason they are locations which are locations which are reliant on travel. Probably a lot of the cost impact on Liverpool is down to the number of goods which comes in by sea.
If transport costs double then the cheap imports become less cheap and people making stuff in the UK start to become better value, which then reduces the amount of trade passing through the docks at Liverpool. This then in turn impacts the city, but benefits those areas where they are already making things.
There is nothing at all in the KPMG report about the cost of transporting goods increasing. The models in it are based on the sensitivity of businesses to rail connectivity when deciding where to invest. I really don't know why you feel the need to completely misinterpret its contents
Model parameters
6.3.75 The parameters governing the importance of transport costs in the trade model have been derived from the shares of cost in each business sector which are attributable to transport based on data in the UK input-output table for 2010. Table 21 shows the data from the UK input-output tables on which the calculation is based.
6.3.76 We have used this data to estimate the share of costs which are due to road and rail transport in each sector. We have made adjustments to include the value of time and inconvenience in transport by applying an uplift of 100% to transport costs. This
broadly reflects the balance between the financial costs of transport and the
generalised journey costs. We have also made an adjustment for the share of rail and road costs that relate to freight so that the cost shares better reflect the cost of
personal travel by car and rail in these sectors. Table 22 shows the parameters that have been used in the analysis.
Correct, they are served by proper long distance intercity services that don't stop at every other village and suburban station. They also continue on to other major destinations which Liverpool has been completely disconnected from. Despite this, every time I have taken this service, or the Virgin service that has overtaken it south of Crewe it has been packed with people's faces squashed against the windows.Yes they do. It's called leisure travel. It's discretionary and price-sensitive.
Note that Manchester and Leeds do not have an equivalent to the LNWR service.
Correct. Though in the background it is roughly possible to identify the Net Present Value of every HS2 service based on the scheme overall, it's contribution to the Economic Case and thus the return on major elements of infrastructure scope.
Any major infrastructure not pulling its weight in benefits terms would be Value Managed out (e.g. HS1 link)
Probably reduce it slightly in all honesty (suspicion only - no evidence to justfy this).
Basically only adding capital cost whilst the existing Phase 2B case already claims all of the benefits from the frequency enhancement and a fair whack of the journey time benefit. (Without being able to claim NPR as a benefit)
I realise that the plural of anecdote is not evidence.
And of course there are busy services on each route (not helped by the fares policy). The point I was making was that the economic case for HS2 to Liverpool is pretty weak when existing (hourly) trains are lightly loaded through much of the day and the peak loadings can be met by strengthening the service at key times.
There may well be a case for a few additional services, but that's a long way from justifying 20 miles of high-speed railway.
Only because in the UK, they refuse to adequately factor in environmental and public health costs when justifying infrastructure projects.But doth not a Business Case make (unless in very, very significant quantity), especially if effectively cross-subsidised.
Try reading the sections referenced below, as from the report:
So on this logic we would do without HS2 altogether, scrap all the 'absurdly cheap fares', see the motorways permanently congested and environmental armageddon hastened. Isn't the point of building railway lines to attract people to use them and take them off the roads?A London-Stafford-Liverpool flow via LNWR is only busy because its
A) Only 4 car
B) Chocked full of people on absurdly cheap fares many of whom would have otherwise driven or not travelled at all
Ah yes, the 'Price them off the trains' approach to demand management. So today we have had Altfish admitting that the HS2 approach to Manchester is convoluted and sub-optimal simply to keep the good people of Wilmslow and Alderly Edge having to drive to the next junction on the M56. Now lanno87 thinks the residents of the Liverpool and Birmingham city regions should have their inter-urban public transport priced at levels, unaffordable to the average resident because some of them want to travel to other cities, and the railway shouldn't cater for discretionary travel, at least not for the plebs.Euston-Liverpool calling at Stafford, Crewe and Runcorn. Pretty fast to me.
Birmingham-Liv hourly calling at Coseley, Wolves, Penkridge, Stafford, Crewe, Runcorn and S Parkway. Not exactly "every other" suburban or village station (where are the villages in that list?)
Anyway, LNWR's crowding on the service could be solved by removing the cheap fares and just charging fares more comparable to Manchester services. Simple. People might get their faces back then.
Also a number of engineering reasonsAh yes, the 'Price them off the trains' approach to demand management. So today we have had Altfish admitting that the HS2 approach to Manchester is convoluted and sub-optimal simply to keep the good people of Wilmslow and Alderly Edge having to drive to the next junction on the M56.
Its funny, how when discussion run about direct trains to Manchester Airport, its the family with 2 kids and 4 suitcase who if made to walk 100m across Piccadilly station, would drive instead, whom suddenly need to be catered for. Whilst the people of Liverpool should just sit on the M6 and like it. The double standards know no bounds on this forum at times.
Funny just checked Manchester to Birmingham and Liverpool to Birmingham prices.... guess which was cheaper.
Bit what has been said here is "Liverpool can wait, Liverpool doesn't matter, Liverpool is second to Leeds" and nobody can quite say exactly why.Nobody is proposing removimg direct train services to Liverpool
Liverpool is not waiting. Liverpool is getting an incrementally enhanced train service in each of phases 1, 2A and 2B, and then again with an eventual HS alignment into Central Liverpool..
Liverpool would eventually end up with the shiniest, newest, most state of the art infrastructure of the lot.
And Liverpool, unlike Manchester, actually gets net extra trains to London! (Future HS2 versus current VTWC)
If Manchester gets 4 and Liverpool 2. Then how is Liverpool gaining net extra? The 4th service will not terminate at Macc. It will go through to Piccadilly and possibly beyond. i.e. Bolton.
Possibly not (but depends on future use of capacity through Stockport - northern stakeholders may have other priorities).
But it wouldn't be a useful service from Manchester, being overtaken by at least one and probably two services running via HS2 throughout. It'd basically be a Bolton-Stoke and a Stoke-Euston service fused together for operational convenience.
Plus, if it ran through every hour (as opposed to just early/late extensions), it'd need extra HS2 rolling stock in the circuit (at least one extra unit) which they may not be willing to pay for.
Point taken. It was more the fact that 6Gman referenced a service towards the capital city in the evening peak. I feel many trains heading towards London at that time, would be significantly less loaded than their equivilents going the other way, irrespective of the pricing structure. Maybe a better example would have been to query the 20:05 which left London Euston at the same time the service 6Gman was refering to arrived.
So we have the ultimate question.Try this for size: https://en.wikipedia.org/wiki/List_of_UK_cities_by_GVA
Actually it might be better if you didn't, it contains some uncomfortable truths.
There is, we can agree on that. That is why I don't want to stop HS2 being built. I have a huge problem with the routing of HS2 north of Crewe and a smaller problem with the Branches into Leeds and Birmingham. Build away to Crewe, get started on the eastern Branch towards Sheffield and Leeds. But hold off on the Crewe-Manchester Alignment until a clear picture of NPR is developed so that the infrastructure can be built to maximise the benefits of the whole rather than the initial limited scope given to HS2.
.Only because in the UK, they refuse to adequately factor in environmental and public health costs when justifying infrastructure projects.
Will bet cold hard cash that it won't.If Manchester gets 4 and Liverpool 2. Then how is Liverpool gaining net extra? The 4th service will not terminate at Macc. It will go through to Piccadilly and possibly beyond. i.e. Bolton.
It'd be very useful for anyone going from Bolton to Birmingham, or London. What's the point of HS2 again?
I asked yesterday about this supposed "Macclesfield" service and other than the couple of people saying of course you wouldn't terminate there and it really means Manchester via Macc, everything else has seemed like nonsense.
If the two Birminghams switch to HS2 they'll be carrying an awful lot of fresh air. I use those trains quite a lot out of Liverpool. The only time they are really busy is in the evening peak out of Liverpool, and (by my estimate) 30-40% of the passengers have alighted by Winsford.
1 train. Scientific !
I'd be carefil with that sort of talk. Seem to remember that current trains to the cities which are getting 400 m captive services are far from full as well. There was conclusive proof of this when i got a seat on a train from Leeds to Stevenage the other Monday teatime.
Yeah people just travel 200 miles on a whim.
Nonsense!
Why should Liverpool wait in line? What has Liverpool done to deserve being second or third rate compared to Leeds?
