Thankyou for the feedback. It's really useful and very much appreciated.
Addressing each point in turn:
Where is the "Value" train going, Manchester?
Yes. The "Value Special" splits into 2 x 200m consists to Victoria via Chat Moss, which appears to be the only route into Manchester that is not full. The main problem with HS2 phase 1 is its limited capacity into Manchester. How else can that be fixed without spending big money?
I'd expect a push for a second Trent Valley local as well.
You can have as many Trent Valley stoppers as you like, provided they terminate at or before Lichfield. Any going beyond LTV will use up a path through Colwich.
That Pendo will be a semi fast as well.
Agreed
No one is working to 10 second increments, I'd be surprised if it goes lower than the current 30 second standard.
That was just a desktop exercise to verify that six trains could terminate and reverse in (just) under 20 minutes, giving a hypothetical maximum throughput of 18tph. A 10tph timetable will only need specifying to the nearest minute. I'll work on that next.
You can do Stafford, Crewe, Wilmslow, Stockport now in 63 minutes. Going via Stoke will save 10 minutes based on a Stoke, Macc and Stockport stop.
Realtime trains suggested 5 minutes saving via Stoke. If it's 10, then I'd send the headline-grabbing premium service that way.
Stoke is an awful place to split and would need significant signalling alterations to make that work. You need another 130m of platform (which can only really be at the South end or a brand new platform) as what is the point of not stopping the first portion if you need 2 minutes to detach anyway? Just run 200m to Macclesfield as originally envisaged. The second portion is going to be waiting 5 minutes at Stoke before it can leave.
My thinking is you don't need a platform to split at Stoke alongside the front portion, if you don't open the doors. So no new building strictly required, and no need for a budget from the Treasury.
The mid-point of the train will be on the 285m platform at Stoke, in case a fitter needs to access to the coupler, and the rear portion will be fully platformed. The HS2 train specification says that trains must be able to split and join when passengers are boarding the stationary part, so my plan is for the front portion to detach and set off to Manchester during the rear portion's dwell time at Stoke. Same in reverse.
I wanted to split at Stoke so that both Stoke and Macc got an hourly service without using up another path through Colwich. Having an HS2 train block the siding to platform 3 for a short while seems a small price to pay, and even that could be avoided by restoring a third track on the existing 3-track bridge over Stoke Road.
The original HS2 plan for a 200m Macclesfield terminator was depended on phase 2a getting built.
Again, needs massive signalling and S&C alterations at Stafford to accommodate 130m extensions as well as rebuilding. Rear unit is waiting 5 minutes before it can depart.
Good point. Stafford is trickier, than I thought. But looking at the track layout again, it looks quite feasible to move the switches and crossing north of Stafford station further north by around 150m each. And replacing Castle Street bridge with a wider span and adding tracks would enable a 400m train to stand at P3 without blocking the through lines between P3 and P2.
But if, as you say, Crewe already has long enough platform 6, then we could split there instead. Though that now makes it imperative to lengthen the southbound platform at Crewe too.
enaRear unit is waiting until the front portion can leave, what is the point of not calling when P6 is 446m long?
railwaydata.co.uk said 390m, but I may have misunderstood. At 445m, then both portions can call at Crewe northbound and it just emphasises the importance of lengthening the 275m southbound P5 to 400m to match. I shall assume this is in the next iteration. Thank you.
How are you doing Handsacre to Edinburgh in 2 hours 40 odd? Colwich to Glasgow is 3 hours 21 now with 6 stops. Say 3½ penalty for each station call and you are at 3 hours.
I must have mis-remembered some figures I worked out previously. Maybe they assumed 2a was in place. Thanks for pointing this out. Looks like extra Edinburgh services on HS2 can wait until 2a or its equivalent gets built. Probably just as well.
Nothing HS2 is going to Rochdale, especially if TRU is the better route. The Chat Moss might not be full, but Ordsall Lane and Victoria aren't far off it. Warrington again needs 150m of platform and significant S&C and signalling alterations to do that.
I suggested Rochdale because Lumo want to terminate there, but it would need electrification of course.
The extra 2tph trains for TRU have to come from somewhere. Leeds acting as a 2tph turnback siding for Victoria seems a neat way to kill two birds with one stone. I'm pretty hopeful that Birmingham-Manchester-Leeds would be a popular and useful through route, especially if those trains continued on to London.
There seems plenty of space around WBQ to slew tracks across and shift switches and crossings at either end of the station to accommodate 400m trains. They're going to have to lengthen platforms on the northern WCML sooner or later anyway. Or it's just throwing away the £50bn invested in phase 1. In the meantime, you just block crossings if necessary.
Isn't that 10 HS2 trains per hour going through Colwich?
No. It's 9 x HS2 200m-long
units through Colwich
The whole point of this proposed service pattern is that those 9 x 200m units go through Colwich joined into just 5 x 400m trains and therefore use up just five paths between them. I can't see any other way to maximise the throughput of HS2 phase 1.
Until we build phase 2a (£7bn) or add 400m platforms in Manchester (£1-3bn)
