Well okay, if you want to get into it. The Chuo Shinkansen is indeed under construction and roughly parallels the original Tōkaidō Line which was built about 60 years ago. It's now at full capacity with 16-car trains.
This is not directly comparable to HS2 however, since an examination of the Tōkaidō Shinkansen timetable demonstrates only something on order of 11-12 trains per hour.
It is also not directly comparable because HS2 is fundamentally not a Shinkansen project - it is much closer to the conception of a High Speed line in Europe (few stations and emphasising very long runs).
They're building the Chuo Shinkansen basically through the Japanese Alps in a straighter line to be faster. It's also currently projected to cost about £70b for the 285km line.
This is not really to do with the technology, but given that the line is constructed through multiple highly congested urban areas, almost entirely in deep tunnels, in Japan, we would expect quite a high price......
The reason they're building this is the overwhelming success of the HSR. We're not even at the 1960's point, never mind the 2030 point. Also you're obsessed by the HS2 budget, and the Chuo Shinkansen is at least £70b for half the length of HS2.
I am not "obsessed" by the budget.
After all I am the one proposing a scheme that is entirely in tunnels... which I fully accept will be somewhat more expensive.
I want the damn thing to be built and work, and to be built on time and on budget - whatever that budget is.
HS2 is a disaster that will be delivered years late and will probably cost as much as a simpler but more highly engineered underground solution.
Also given the maximum speed for conventional Japanese trains is about 80mph or so, we are a long way past 1960s Japan......
But as I wrote, CURRENTLY there is only really the experimental test track in Japan and the (rubbish) Pudong Airport link. IF the Japanese MagLev line is brilliant then I would fully support building one in Britain, but we certainly can't wait till 2030ish to find out and then start planning one. We needed to start building HSR in Britain decades ago. HS2 is our chance to build something now.
So you argue that HS2 is a ready-to-go off-the-shelf solution?
But it isn't.
Bespoke trains used nowhere else, with totally random non standard platform heights, a ludicrous speed profile (everyone has given up on 360km/h, let alone 400km/h), and a ridiculously over-complicated project schedule with thousands of moving parts.
If they wanted an off-the-shelf scheme it would look nothing like this.
And as you ignored it, I'll write it again. China a decade ago looked into building from scratch MagLev HSR and rejected it in favour of traditional HSR and look at how good that is.
The Chinese HSR network where bridges just fall down at random?
And it is only rapidly built because anyone who questions the party line, technology or routing simply gets disappeared?
But it won't be 1 generation behind the world, especially not in 5 years' time. Everywhere in the world that has an operating HSR line (or opening within 5 years) has it on rails!
But it won't be built in five years will it?
It won't even be built in ten in all likelihood.
The other more important thing is to think about the fact that an isolated line sees very little benefit.
But this simply isn't true.
Otherwise metro lines would bring very little actual benefit.
MagLev solutions are so much faster than everything else that the time penalty from changing trains simply melts away.
When you can get to Manchester in 35 minutes, waiting a few minutes for your train there makes little difference to you - you will still do it.
