There is no issue with Long Swing Link vehicles operating on the ECML. The wire rope version of the swing link is an improved design from the original stirrup.
The main issue is that BT10 bogies that are fitted with Long Swing Links are prohibited from operating on third rail lines, as there is a risk that the swing link may foul the third rail.
The vehicles that are fitted with one or more Long Swing Link bogies have the letters LSL painted on the body end, below the main data panel.
Yes, I am aware of the LSL lettering
This was an issue in BR (Intercity) days as quite often trailers could be swapped at Craigentinny from an East Coast set to a Cross Country set
Obviously that doesn't happen now, so its not a major issue
When I worked on Intercity East Coast it was basic knowledge to know about the bogies and to recognise a "correctly" operating one, so that a faulty one if seen could be reported
I used to also have a list of which East Coast Mark 3 trailers had SSL or LSL, as well as some of the other minor variations between them
I remember working on one set where the bogie on one trailer had been reported as having a knocking noise as it was travelling northbound
The bogie was examined at Edinburgh but nothing wrong could found
Shortly after departure from Stonehaven several passengers reported there had been a banging noise along the side of the train (which was quite common on HST when they lift loose ballast)
On arrival in Aberdeen I had another look at the bogie, several components were now missing, with lovely clean metal edges where the rest of the bogie was dirty!
The coach was taken out of the set and dumped in Aberdeen for three days for repair, the same set came back and the coach was reinserted (ironically making it temporarily into a 9 coach set)
