Buy your ticket sooner rather than later with an itinerary for the service you want to return on. In The unlikely event* that it doesn’t run then you’ll have an extra bit of supporting documentation.
Consider the options. You could excess the return part only at Sheffield which would be only half the difference in fare. So it’s always cheaper to do this even when services are running. However you may wish to ask the guard if they’ll just let you travel that way. An EMT guard allowing you to travel ‘via nottingham’ has given you authority to board the service from Nottingham to Mansfield.
Also consider getting a partial refund from northern and catching the 53 bus which takes about the same time as the Via Worksop route when you factor in a tedious wait at Worksop and costs about £6-7
*no northern trains have run on Saturday since August and nobrelkacwmebt buses since October.
