Huntingdon bay platform one
Bringback309s
22 Aug 2013
It looks like platform one at Huntingdon, the bay platform doesn't see any scheduled services now. How did Northbound trains enter the platform previously on services such as the 16.22 that used to run from Kings Cross? Where are the crossovers?
It would have required a shunt, the question was previously asked and answered here:
The Saturday morning train used to run ECS from Peterborough and then simply shunt back into the bay.
The 16:22 King's Cross to Huntingdon didn't use the bay - it simply ran ECS to Connington where it reversed and ran back to Huntingdon, re-entering service in platform 2.
HamworthyGoods
15 Jan 2019
Trailing direction bays were quite common during the construction of the railways as they saved having a facing point lock, many track layouts are a legacy from that where it’s not worth subsequently changing the layout.
As traffic was generally lighter in those days the trains would arrive elsewhere in the station and then shunt into the bay to stable prior to departure. This often worked well with steam hauled services as they wouldn’t be able to run around in the bay anyway.
Places which spring to mind where this occurs/occurred are Huntingdon, Oxted and Taunton, I’m sure there are many more!
4-SUB 4732
7 Jan 2018
I remember that Saturday morning one well. Made very little sense (or so it felt) really, and that signal that only led to the Up Slow signal anyway was an odd one, but I digress. Does it even fit an 8/700 now? I want to say no.
I don't see why it shouldn't take a RLU, as the SA states the berth length as being 166m, which is only 1m shorter than King's Cross platform 9. So I'd say the answer is yes, unless there's any local arrangement. Of course RLUs are barely booked to see the Peterborough route, there have been the odd diagrammed working on weekends, but I'm not sure if this applies at the moment.
Likewise I never really saw why the Saturday morning move happened, the only things to think of are route knowledge retention, or even keeping the rails shiny. In reality the Huntingdon bay is more of a glorified siding for things like track machines, which just happens to double up as a bay platform.
Kite159
27 Jan 2014
West of Andover
IIRC that Saturday starter allowed for the previous Peterborough - London train to run semifast (St Neots & Biggleswade only).
Maybe pathing between Peterborough & Huntingdon was an issue to why it couldn't simply be a Peterborough - London stopper running a couple minutes behind that semifast.
OFFDN
30 Nov 2016
Herne Hill
The bay is of little to no use these days. 8 car 387s and 8 car 700/0s are not cleared to use it due to signal sighting issues.
Bikeman78
26 Apr 2018
Hereford is another example. I think the Birmingham trains used to do a double shunt to access it. More recently the signalling has been altered so the Birmingham trains reverse in the down loop and head back in service from that platform.
