Nicholas Lewis
Biofuels need land take though but could certainly be a player for residual liquid fueled prime movers for sure.There will be places that wiring isn't the best solution to when taken as a whole provided there's an alternative that works on a small scale ( remote branches are pretty likely candidates ) but at a small scale like that then biofuels are also a candidate, surely. Not politically ( in the broad sense of social opinion ) acceptable right now. I'm not sure about hydrogen duration - once you factor containment in the energy density advantage collapses, You can construct a system that's not dependent on rare resources, but if you want to harvest - which is quite critical, if you don't then your efficiency just plummeted - you're going to need some batteries anyway, The whole area is a lot messier than people like to make out :/
