Ickenham overrun/SPAD, 12th March 2022
Tangent
6 Jun 2012
I am surprised that this didn't end up as a RAIB investigation:
The driver fell asleep between Ruislip and Ickenham, failing to initiate the brakes in time to bring the Tube to a stop. This resulted in the train overrunning the platform at Ickenham station and going through a red signal without permission.
Evening Standard article today:
TfL response to FOI request, November 2022
The correct operational procedures were implemented following the incident and welfare checks undertaken with the train operator who was relieved from duty whilst further fact finding was undertaken. There was a delay associated with the incident but no injury or damage occurred as a result.
In accordance with our obligations under Data Protection legislation, information on what action was taken against the driver has been withheld as required by section 40(2) of the FOI Act.
There is actually some potential for collision on LU if a driver disregards a starting signal at full speed, as in some places overlaps on starting signals are of nominal length only, though the way things are designed extra protection is provided if there is potential for a train ahead to *routinely* stop in a location protected only by a nominal overlap.
Fatigue remains the big elephant in the room. It is very difficult to reconcile an industry which has always worked with extreme and erratic shift patterns with natural human fatigue. It’s something to remember when people moan about how highly train drivers are paid, many people might fancy the salary but either wouldn’t want or couldn’t cope with the shift patterns, and the self-discipline they require including when not at work.
12LDA28C
14 Oct 2022
The back of beyond
Indeed, and yet the industry (or rather the Government via the DfT and RDG) wants to move towards even more punishing / fatiguing rosters with even greater movement off spare, late notice movement of Rest Days etc, all in the name of 'efficiency'.
14 Jan 2022
If it were possible to "Make" Government and the DfT exist on similar shift patterns they'd be a lot less keen on inflicting increases in misery on others. Or spouting nonsense in press releases about "efficiency" when they have literally no idea what the word means.
TomCrame
6 Jul 2005
There's very little potential in such a circumstance. The normal design process is to calculate the full speed overlap of a starting signal, and if there is no credible collision risk within that calculated overlap (i.e. no berth or confliction within it) then a short overlap for 35km/h may be provided. If there is a confliction then things are reverse engineered, the longest possible overlap is provided and then speed control is provided which validates the use of that shorter overlap.
For example, if there isn't enough space for a full speed overlap of 50mph but there is enough for 38mph, then a 38mph overlap is provided on the starter and speed control is provided on approach. That speed controlled signal's overlap must be good for 50mph, and the signal can only clear if the train is approaching at 38mph (or less, depending on whether or not you take reacceleration into account.)
Most if not all of the very short starter overlaps (which truly were for a nominal speed of <15mph) have now been removed.
Surreytraveller
21 Oct 2009
philthetube
5 Jan 2016
Metropolitan line trains are designed in a way that makes it possible to stand while driving.
Mawkie
17 Feb 2016
There is a good example I think on the Picadilly Line at Leicester Sq (eastbound) with a speed controlled train stop ¾ of the way down the platform. Obviously Covent Garden is very close. If I recall, it's set to drop at 15 or 16mph?
rebmcr
15 Nov 2011
St Neots
Silly question time then; are they not ATO?!
Metropolitan line trains are not currently provided with ATO-compatible signalling as far north as Ickenham.
Piccadilly line trains have no ATO capability at all.
Towers
30 Aug 2021
Well, didn't know that! My assumption was that all the S Stock was ATO!
Strathclyder
12 Jun 2013
Clydebank
OT, but this is what scuppered my childhood aspirations of becoming a train driver once they came into contact with that cold, unflinching object known as reality. I know full well I'd find it extremely difficult, if not outright impossible, to adapt/adjust my sleeping patterns (which are all too easily disrupted) to the shift patterns and to maintain the self-discipline needed, on and off-duty. I just ain't built for it. It's something I've long since made peace with and it has only heightened my respect & admiration for those behind the controls.
Presumably there's still plenty of 35 km/h overlaps on starting signals in the tunnel section of the Picc Line, which in many cases seem unlikely to be sufficient for a train running at full speed and making no attempt to slow down for the platform. I know a collision would be the result of a number of things coinciding, however I wouldn't fancy the chances of something running through somewhere like Wood Green westbound at full speed (bottom of a 1 in 60 downhill gradient) and stopping within 70 metres!
