IET cab buttons: What do these ones do?
snowball
4 Mar 2013
Now there are four class 80x threads I have no idea which one to place this question in! It's not geographically specific. I'll compromise by posting it in two of them.
On page 83 of the October Modern Railways therE's a photograph of the driver's control panel.
Item 9 is "snow brake pushbutton". What do the brakes do differently in snow?
Item 20 is "Wheel slip/slide warning and train wash pushbuttons". What is/are the train wash pushbutton(s)? Presumably not actually a device to wash the train. I suppose it could be something to close apertures when going through a train wash?
snowball
4 Mar 2013
FGW_DID
23 Jun 2011
81E
Train wash mode enables a unit to go through the train wash at a set speed without the driver having to worry about maintaining the very low speeds themselves (think cruise control on a car). Our carriage wash is 3MPH, I think the 387s are fitted with train wash mode as well.
Clip
28 Jun 2010
Im just guessing on the train wash side of things but thats probably to regulate it at 3kmh or whatever it needs to be when going through the wash - a sort of slow cruise control id imagine.
irish_rail
30 Oct 2013
Plymouth
Snowbrakemode applies a slight bit of friction brake whilst powering or coasting if enabled and temperature is below 4 degrees. Replaces the need for regular running brake tests in falling snow
cjmillsnun
13 Feb 2011
I would assume this would do light brake applications regularly to clear the pads and discs of snow. It also may change the WSP characteristics.
Again a guess, but it could be there to hold the train at the correct speed to go through the wash?
broadgage
11 Aug 2012
Somerset
Perhaps the train wash mode also tells the computers not to be frightened of all the water ! "don't worry, It is fresh water, not like that nasty salty water found at Dawlish. Don't be frightened and trip everything, it is for your own good, and anyway it is not for long"
jon0844
1 Feb 2009
It activates the window goggles and water wings.
