LOL The Irony
In the event you can't do the other two.Why on earth would you do that?
Demolish and rebuild them to fit in with the rail infrastructure.Ordsall Lane flyover, to remove conflicting movements Victoria - Chat Moss and Oxford Road - Salford Crescent. There are some drawings around and the only problem might be the gradients required to avoid the road bridges.
Clearly I am missing something then, as how does making people change trains to get to Manchester improve anything whatsoever just to stop a conflict at Slade Lane? The priority of flows and passengers is all wrong.In the event you can't do the other two.
Where is the Westbound traffic going from Trafford Park?Five platforms at Salford Central renaming it to Manchester Spinningfields. Huge amount of development over there and needs a much improved facility.
Westbound exit to Trafford Park. Help alleviate congestion.
Bi directional passing loops at Irlam and Eccles (3rd platform reinstated). Connect sidings at Warrington Central at both ends to build in redundancy.
All platforms lengthened to six carriages.
Cheap and doable now.
Whilst having the ability to terminate trains and Stockport and reverse them there would improve operational convenience and sometimes help with recovery from disruption, and it would also have made last Sunday's workings easier (trains having to reverse over Stockport viaduct or go to Longsight and back), I agree with The Planner that this is also potentially putting the operation of the railways in front of passenger service. At the moment the Cardiff-Manchester services frequently get reversed at Wilmslow anyway, when they're running late as they often do, and although I've not been at the station when this happens it's usually a cross-platform change from platform 2 to platform 3 for the onward journey - annoying but could be worse. The only platform at Stockport with running signals at both ends is platform 1, so the Stalybridge-Stockport-Stalybridge service is booked to reverse there. But Stockport works well most of the time, and some of the proposed "improvements" actually make things worse for passengers.What would Stockport solve?
Bring back the Fallowfield loop for the one train a day which used to use it for a Trafford Park to Holyhead freightliner when it existed, which went around the houses and through Manchester Victoria after leaving Trafford Park at about 17:30.Where is the Westbound traffic going from Trafford Park?
Adds shed loads of time into the schedules and 775m trains crossing over at South Parkway. No thanks.CLC and then reverse at Edge Hill. Seen a lot worse freight routes.
Build a link from Glazebrook to the Chat Moss at Lowton.Where is the Westbound traffic going from Trafford Park?
Don't most services from the Bolton side go via the direct line to Vic nearer the A6 and not down the Windsor Link then left to Vic per the Chat Moss ones?
Obviously there’s already a free bus service from Victoria to Piccadilly and a regular tram service and direct trains via the expensive Chord (and twenty trams an hour from Victoria to Castlefield), but this doesn’t seem to be enough to wean people off direct services
I've said before I wouldn't have built Ordsall, it has done very little good and lots of bad
Talking of politics, there’s the apparent need for a direct service from Leeds to Manchester Airport (I know that we both dispute this, and that the sky hasn’t fallen in in Sheffield since we lost the hourly Airport service that we’ve had since the 1990s, but it’s political).
So if your answer is that we should have built another Piccadilly - Victoria route (albeit one to exclusively benefit those living west of Manchester)
then what would happen to the TPE services that the Chord removes from Piccadilly? We’d still have them containing other services? Or you think you could get away with cutting one of the few long distance services to Liverpool? Or you’d have the Scarborough - Liverpool running via Victoria/ Chat Moss but none of the other TPE services using Victoria, leaving some big gaps in the fast services? Would you have gone for the double whammy of removing the Airport link too and terminating the Newcastle/ Middlesbrough services in the main shed?
Maybe not.
I don't think it is worth reinstating a railway line just for one train per day, especially as it would involve closure of a popular cycle and walking route, and the demolition of the Sainsburys supermarket at Fallowfield.
Building an orbital extension to Metrolink starting at St Werbergh's Road, running round the Fallowfield Loop and then joining on to the Ashton Under Lyne route might be worth it, but that is probably just a fantasy.
It wasn't a serious suggestion! However it's interesting to note that once it was possible to get out of Trafford Park and head west without having to reverse, even though it was a bit of a long way round.I don't think it is worth reinstating a railway line just for one train per day, especially as it would involve closure of a popular cycle and walking route, and the demolition of the Sainsburys supermarket at Fallowfield.
I thought the plan was to use the old Mayfield station siteIsn't the space to the north of P1/2 going to be the HS2 station?
No, you're thinking of the wrong side of the station; HS2 is going alongside platform 1 to the north/east, Mayfield is in the process of being "redeveloped" for other reasons and is now a trendy foodie place amongst other things.I thought the plan was to use the old Mayfield station site
Splitting 13/14 in 2 along with a new entrance for each extremity from outside the trainshed. The waiting rooms would be taken off the platforms to further increase capacity and make some points changes so that 2 double 185s could be accommodated possibly with 1 door on each train out of use. This would make Castlefield a lot more reliable, reducing dwell times for relatively little cost.
Its been on the drawing board since SELNEC days. removing conflicts at junction will always improve reliability and increase capacity.Grade separation of Slade Ln, an additional platform and remodeling of Stockport or Piccadilly 15/16. They're all too important to pick just one so I listed all three.
I would reconfigure Manchester Piccadilly.
I would either close/relocate P9& 10 to the North side of the station and rebuild P11 &12 with the tracks in the middle.
A new elongated concourse connecting into the existing concourse over where P9 &10 used to be!
I would also have ramped access up to the South platform to maintain level access on both sides when lifts are fecked!
I think the chance to create a fast route from Stockport to Victoria was lost when the Ashton Moss Jn to Droylesden Jn line was closed, leaving just today's very slow route via Crowthorn Jn and Ashton Moss South and North Jns. I suppose the rationale at the time was that the latter route also gave access towards Stalybridge avoiding Guide Bridge from Ashton Moss South Jn to OA&GBJn and the the direct line to Droylesden was a duplicate — but then that eastwards curve was closed, leaving just the westwards route for which the Droylesden line would have been a much better alternative.I would upgrade and electrify the Denton line to allow fast running for services from Salford Crescent and beyond to use it and restore & create new connections to Stockport and beyond, without bringing back the Piccadilly 13/14 - Stockport conflicts. This could work well if the WCML fast tracks are moved to the western side of the line, as mentioned earlier. Perhaps the solution for Levenshulme and Heaton Chapel could be to make both of them one-platform stations, located on the east side (the new up slow line) with a loop from the down slow line?
Half hourly service between Salford-Rochdale/beyond (one from Bolton and one from Atherton), the rest of the Salford-Victoria services can then run towards Stockport and beyond via the upgraded Denton line.
From an Outside perspective:
Improve the Deansgate corridor by removing the through platforms at Piccadilly and expanding Oxford Road (maybe a rebuild and some subterranean platforms for those heading towards Warrington and Liverpool) to have all through traffic
