And not just on a sidewalk. When going alongside a 60mph road you need a grass verge at the very least to separate you.
Agreed.
Curiously there are some examples in the UK that have been around for a long time - a few roads around West Lancashire have the full Dutch arrangement (i.e. separate pavement and cycle path), such as the A59 dual carriageway around Ormskirk.
The annoyance about the A421 on that section is that there's plenty of room within the existing area the road takes up to do it if the drainage ditch was replaced with a proper piped drainage system. So no land acquisition would be needed.
Not that these single carriageway roads should be 60mph, I see that Ireland is reducing speed limits.
Personally I'd like to see the van limits of 50-60-70 for single, dual and motorway applying to all vehicles*, possibly adding a 30 or 40mph one for single carriageways with no marked centreline (for rural roads). It would considerably reduce overtaking which is the most dangerous thing any driver ever does, and the 60 could be applied to motorways without a hard shoulder too (i.e. the definition for signing a road up to 70 would be "a segregated dual carriageway with full crash barriers in the central reservation where cycling and pedestrianism is not permitted and where there is a continuous hard shoulder at least wide enough for a broken down vehicle of maximum normal width** to be parked fully off the carriageway").
* Including lorries - 50 for lorries rather than 40 on singles has actually been quite positive in reducing overtaking. Obviously any vehicle with a legally mandated limiter would stop there, so de-facto it'd be 50-56-56 for lorries and 50-60-62 for coaches.
* I seem to recall that being 2.5m, above that you need special "wide load" provisions.
