Is there a single TOC journey planner?
LuSiVe
12 Feb 2013
Chesterfield
Is there anywhere you can plan a journey restricting it to the trains of a single operating company (specifically Northern in this case)?
I did do a search of the forum but I don't seem to be using the right words to find any existing threads.
sciisfun
28 Aug 2015
south west
GWR can do their services with a pit of poking around, cant get the trick to work with the northern planner unfortunately
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
The only TOC website that now can plan a single-TOC itinerary properly is Caledonian Sleeper, if you access it from this URL: https://uk.sleeper.scot/ and click "Additional Options", then select "Show only journeys for" and pick the TOC you're interested in. It's not as good as FastJP though, e.g. it can't find any itineraries for Stoke-on-Trent to Lincoln using Northern only (admittedly a tough test, as most Northern-only itineraries are nearly 2 hours longer than the fastest itineraries).
