Journey Planner Error?
Greenback
Emeritus Moderator
9 Aug 2009
Llanelli
We will be visiting the Bodmin Steam Railway on Saturday 10 July, and will be back at Bodmin Parkway around 1515.
According to the Traveline South West site, and the FGW Plymouth - Penzance timetable, the Royal Duchy leaves Bodmin Parkway at 1549 and arives at Par at 1558/1559.
I've looked on the East Coast booking site and this tells me that the trains from Bodmin are at 1427 and 1645. I checked a train line powered site as well and got the same result!
Is this just an error? Or is the train not running on 10 July and the Traveline is wrong?
boing_uk
18 May 2009
Blackburn
Something has changed on National Rail Enquiries telephone service recently thats for sure. When looking for services from "Blackburn" to "Blackpool" at around 6pm, it completely misses the 18:35 to Blackpool South, instead giving only the 18:15 and 18:44 to Blackpool North, even though it a) always used to pick it up and b) it picks up the other xx:35 services.
455driver
10 May 2010
Well I have looked at Plymouth to Penzance and it wont give me the times for the Royal Duchy (1512-1713) or any journey off Pad (1206).
Either it isnt running (unlikely) or its been missed off the database.
Have contacted FGW and awaiting reply.
Benno
28 Apr 2010
Just checked on TRUST and the 12.06 Paddington to Penzance (15.49 at Bodmin Parkway) is indeed cancelled.
Also cancelled are:
10.06 Paddington - Penzance
14.00 Penzance - Paddington
16.45 Penzance - Plymouth
philjo
9 Jun 2009
The Royal Duchy is shown as calling at Bodmin at 15:49 in the printed timetables, both the FGW version (arr 15:48 ) and table 135 of the NTT:
http://www.firstgreatwestern.co.uk/Documents/Custom/May%202010%20amendments/Further%20amends/GW10M_TT04_WEB_%283%29.pdf
http://www.networkrail.co.uk/browse%20documents/eNRT/May10/timetables/Table135.pdf
The Paddington trains at that time have got the "R" (seat reservations recommended) symbol. The other trains you have mentioned do not. Maybe for some reason the system assumes these will be fully booked (by Bodmin a number of passengers would have left the train) so doesn't display them?
Or perhaps the database has got them recorded for set down only ???
455driver
10 May 2010
Just rang Customer Services and it is cancelled due to engineering work (as is the 1006), but she couldn't say where it is or why the 1106, 1306 and 1406 are all running normally :roll:
With those 4 trains cancelled, I would like to see the crew workings to see how they interact!
Greenback
Emeritus Moderator
9 Aug 2009
Llanelli
Also cancelled are:
Do you know why these trains are shown as not running? There's no info on the timetable alterations and engineering works section of the FGW site. You'd think that would warrant a mention, since it would be quite a busy train!
I thought that, and double checked the timetable for obscure notes, but there aren't any. I also doubt it would be jam packed after Plymouth, and I;m sure they run much busier trains on other parts of their network!
devon_metro
11 Oct 2005
I can see no reason why engineering would affect these trains and find it HIGHLY unlikely that these trains will be cancelled. Very odd.
Greenback
Emeritus Moderator
9 Aug 2009
Llanelli
I hope it is running. Don't fancy being stuck at Bodmin Parkway for an hour and a half!
Is there a pub or anything nearby just in case? It looks pretty quiet around there from what I've seen from the train window in the past!
12 Feb 2010
Taunton
To be quiet honest I wouldn't trust NRE as far as I could throw it.
I took part in a online survey they were doing (may still be doing it) and completely lambasted it and the designers of the so called "New & Improved" website.
I stated that I thought it was all "Style & No Substance", with puerile & unnecessary graphics, a poor and confusing user interface, which meant the user had to do considerably more work to find out the same information as before.
The service was unreliable & regularly lagged behind what was happening in realtime, that it's malformed if you use the mobile site on any mobile device (PDA/Smartphone) & even if you get your device to use the full site when you do an enquiry it comes up with inactivity errors. I also stated that a teenager could do considerably better.
See, I pull no punches.
richw
10 Jun 2010
Liskeard
any chance the HST unit could be faulty for that diagram, is the hst involved in last weeks derailment at Long Rock out of service? with not enough stock to cover these diagrams, then that would be cancelled due to engineering to the rolling stock?
louis97
14 May 2008
Derby
Have just looked on Journey Planner and these services are also not appearing on:
3rd July
17th July
24th July
Must be some kind of fault with journey planner, they can't not run these services 4 weekends in a row!
12 Feb 2010
Taunton
Unless the damage was very serious, then I doubt it, as other diagrams would be affected on a daily basis. A weekday service is more intensive than a Saturday one & it's running normally.
In fact an HST was used on Paignton - Cardiff a few days ago vice a LHCS set.
455driver
10 May 2010
That far ahead :shock:, they have spare power cars and coaches so the set will probably be back in service now with just the damaged vehicles being out for repair. It is all rather strange indeed.
87015
3 Mar 2006
GEML/WCML/SR
As said on here previously, there are currently major issues with NRs new train planning system leading to lots of missing, incorrect and even extra trains in Trust and Journeyplanners. Most LTP errors have I believed now been fixed in public facing conditions but STP alterations are still a mess in places.
It is however very poor from FGW customer services to tell passengers trains are cancelled, the issues are known about and customer services should have at least checked what engineering work is taking place (none according to FGW website) and the planned revised timetables for that week.
Peter Mugridge
8 Apr 2010
Epsom
Are they running diversions via the Yeovil connecting spur?
That would explain why half are running and half are not.
Frontera2
11 Dec 2007
I can confirm that these trains ARE running - they appear to have been cancelled every Saturday from 03/07 until 04/09 inclusive.
This is being looked at as a matter of urgency by FGW Train Planning / Network Rail
Greenback
Emeritus Moderator
9 Aug 2009
Llanelli
Excellent news, thanks a lot!
