Chris M
I literally quoted it in my reply to you:Where does it? I've had another look and still don't see anything.
As yet a fix has not been identified, with a timescale not yet known.
I'm confused. How is "the answer to my question is nobody knows" (what I said) any different to "a timescale not yet known" (what the RMT said)??I literally quoted it in my reply to you:
Service delay refund refused by TFL as they claim I wasn't delayed as I didn't get on a service because the service wasn't running.
I will send them a complaint and see what happens.That's wrong, they're probably just trying to fob you off.
Severe delays again this morning due to the issue. Anybody have any idea how long this will take to sort out?
All trains were inspected by the weekend, so it’s just a case of fixing the few units that are broken.
I'll assume from that that the answer to my question is nobody knows.
The latest news that has been made public is that from the RMT quoted and linked in message #12. It includes the sentence:
So there is no need to assume anything.As yet a fix has not been identified, with a timescale not yet known.
Que?..You asked a question.
Other members posted various things, one of which directly answered your question.
You quoted a post that didn't answer your question, stating that you were going to assume the answer to your question based on the quoted post (which gave no basis on which to make the assumption).
I then quoted the post that did answer your question (specifically the part that answered your question), pointing out that it answered your question, and stating that you didn't need to assume anything.
Since then the only relevant statements you have made (as distinct from questions asked) are that there has been no answer to your question.
I see the journey cost me £5.30 rather than the £2.90 it would have done if the Jubilee line had been running. Will TFL give me a full refund?
There are two aspects to this:I suppose I'll wait and see although I'm surprised that what was effectively the same journey cost me almost twice as much.
If it’s true that only the add-on cars are affected, these were built by CAF, not Alstom like the original 96’ cars and all the 95’ cars.Interesting as there have been no indications of problems with the related 95 stock which was constructed around the same time as the first batch of the 96 stock
Just sent a complaint via their online form. Let's see if anything happens. I know the amount involved isn't great but that's not the point.That's wrong, they're probably just trying to fob you off.
the root cause for the cracks appearing has not been fully established, in turn an appropriate fix hasn’tbeen developed
trains considered Cat 2 will now be stopped rather than subject to checks every 3 days. As a result,10 trains are currently stopped (8 Cat 1, 2Cat2).
there [is] an issue with bolts shearing under the train which may have contributed to the cracks and that cracks have been found in other areas of the train separate to the special trailer car [7th car], which was originally believed to be the only area effected
The train and track software is only setup for 7-car operation, platform doors etc.Sounds like this might drag on a while. I wonder will we see 6-car operation?
Sorted.I will send them a complaint and see what happens.
I'm shocked that the Jubilee line stock was taken out of service as a precaution - for a train of nearly 25 years old, these perform so smoothly!
95 stock is not affected - different design in the affected area.Interesting as there have been no indications of problems with the related 95 stock which was constructed around the same time as the first batch of the 96 stock
Ah but the Jubilee has been ATO for much longer.
As much as its a problem to not have the full fleet available, it could be worse - I feel sure that it was a coupling issue which caused the experimental 1986 ts trains to come to grief ... also on the Jubilee line.
Then there were the total withdrawals of the 1992ts trains on the Central and Waterloo & City in circa 2003.
Nothing to do with the single leaf doors, stepper controlled accelerators or TCMS issues?
And the W&C was for overhaul and refurb...
