Kingston to Dartford, which route?
londonbridge
30 Jun 2010
Single fare finder shows an offpeak fare of £4 for this journey, but by which route? Looking at the map I’m assuming it’s going to be Clapham Junction then overground to Denmark hill?
The stated routes for that fare are either via Elephant & Castle (EPH), or via Clapham North (CPN) & High Street (CLP).
Changing at Clapham Junction (CLR) and Peckham Rye (PMR) would seem to make a lot more sense to me - but as the default route is charged via Zone 1 and you wouldn't pass through any barriers when changing at CLJ & PMR, I don't think you'd be able to take advantage of the 'avoiding Zone 1' fare if you went that way.
I suspect you're therefore forced to take the slower route with an OSI at EPH or CPN & CLP to take advantage of the cheaper 'avoiding Zone 1' fare. Ironically I think you might even be charged the 'avoiding Zone 1' fare if you do an OSI at both EPH and London Bridge (LBG) - despite that involving travel via Zone 1. Perhaps @MikeWh can clarify.
Horizon22
Jobs & Careers
8 Sep 2019
There's pink readers on Clapham Junction they could use no?
Skimpot flyer
16 Nov 2012
On a related note, ‘Some journeys are charged via Zone 1 irrespective of the route taken’ is sometimes displayed when looking up specific fares on TfL’s single fare finder.
Can anyone give an example?
greatkingrat
20 Jan 2011
One example would be Deptford - New Cross. This is charged as Z1-2 assuming travel via London Bridge. There is no alternative route shown, even though you could travel via Charlton and Lewisham (although most people would just walk it!)
Skimpot flyer
16 Nov 2012
Are there still direct trains, round via Slade Green? :D
akm
21 Mar 2018
If you reckon you can do it within MJT (which I reckon you probably could), you could do:
Kingston westbound NR round the loop to Richmond;
behind-gateline interchange to District;
District line to Ealing Broadway or Paddington;
behind-gateline interchange to Elizabeth line;
EL eastbound all the way to Abbey Wood;
NR to Dartford
£4, bargain. Takes a while though...
MikeWh
15 Jun 2010
Crayford
Yes, via Slade Green and Barnehurst.
The other alternative is via Greenwich, DLR to Lewisham, then New Cross, but even that is quite a roundabout route compared to in and out of London Bridge.
hkstudent
11 Nov 2018
SE London
If taking the DLR, that may trigger a mixed mode journey, if OP has travelled on NR via zone 1.
MikeWh
15 Jun 2010
Crayford
I don't understand what you're suggesting here. My response was to the sub question about travelling from New Cross to Deptford. You either go via zone 1 on NR or use the DLR to avoid zone 1. Sadly the system doesn't cater for the latter as there is no fare set.
hkstudent
11 Nov 2018
SE London
Ah, sorry about that.
I think the issue here is likely, DfT dictated that noone will go not via zone 1, this situations happen more often on Southeastern area than Southern or Thameslink area which more non zone 1 options are available.
plugwash
29 May 2015
That's not what I see when I look on the fare finder. When I look it up on the fare finder I see a default fare of £4 and then alterative routes "Using National Rail services only via Waterloo East/Waterloo (or Victoria and Clapham Junction)" and "Travelling on National Rail and London Underground in Zone 1 changing at Blackfriars, Cannon Street, Charing Cross, London Bridge, Victoria, Waterloo or Waterloo East"
