I think it was possible that the protective steelwork may be slightly lower than the bridge sign says.
For a long time (certainly over 60 years, probably several decades more), bridges less than 16'6" over public roads have needed to be signed, and almost all new bridges over roads (not just motorways) are about that height or a few inches higher. Certain roads are designated high load routes and new bridges over those are a bit higher still.I think most motorway bridges are 17 ft or more
Except for the footbridge near Maidstone over the M20 which got knocked down by a lorry passing on the hard shoulder a year or so ago!I think most motorway bridges are 17 ft or more
My correspondent heard the lorry driver insist his height was 4.0m and the police measured the clearance to be 4.0m, not the 4.2m on the bridge.
Although if that was true, not sure why it hadn’t been noticed before.
The driver in that case is awaiting trial on multiple charges of dangerous driving and criminal damage, which implies that his load (an excavator) was over height at the time, rather than any lack of normal clearance under the bridge. The charges are sufficiently serious that the case has been sent to Crown Court rather than being dealt with by magistrates.Except for the footbridge near Maidstone over the M20 which got knocked down by a lorry passing on the hard shoulder a year or so ago!
http://www.kentonline.co.uk/maidstone/news/m20-bridge-collapse-driver-in-court-120695/
Without commenting on this particular case, excavators are notorious for their arms raising themselves in transit as the oil in the rams heats up and lifts the arm. For this reason, any excavator in transit is supposed to have its moveable arm chained down, over and above any chaining necessary for securing the whole machine to the lorry.There is no height limits though on UK roads and you are not supposed to stop on motorways, but it says he passed on the hard shoulder, sounds like all the fact are not present in the press release.
Another point is bridges should be marked both in metric and imperial measurements, many older drivers wouldnt have a clue what 3.5 meters means, they were taught at school in imperial measurements, meters came along later.
It's "metres". Speaking in my mid 60s, I find it rather amusing to think 'many older drivers' might not know about metric measurements. Even my late mother, born 1929, was taught metric measurements at school. She used to get really wound up about this myth of 'older people' not understanding the metric system.
As I understood it, dual imperial/metric measurements were only included in the traffic sign regulations a few years ago, for use at low bridges specifically, for the benefit of foreign drivers who might not understand feet and inches...
Whatever the rights and wrongs of it all surely it is better to display both metric and imperial on bridges to reduce the chances of an accident?
Do you actually need to understand or have much a concept of it? There's a number on the bridge, and there's a number which is your height. If the first number is smaller than the other carrying on driving is an unwise manoeuvre.
So, if the bridge is 10 feet high and you know your vehicle is 3.5 meters tall, you're perfectly safe because 3.5 is less than 10? (Hint: 10 feet is actually only approximately 3.05 meters). Obviously you need to understand heights and units to drive safely...
Thats correct, also many driver change trailers on a regular basis, the number in the cab doesnt automatically change as you pick up a trailer
Indeed and the height on the trailer cannot always be taken as gospel, it can vary according to the unit underneath it.
Thats correct, also many driver change trailers on a regular basis, the number in the cab doesnt automatically change as you pick up a trailer [/
So it is up to whoever is responsible for the vehicle, i.e. the driver, to make a note of its actual height and neither guess or just ignore it. Either the driver is responsible enough to drive what can be a hazardous vehicle or he/she should get out of the job. If a train overshoots/undershoots a platform (not a terminal one) it is inconvenient/embarrassing/possibly disciplinary. If an inconsiderate driver abuses the restictions on road height clearance, it could be fatal or cause serious injury of those who were just unlucky to be in the wirong place at the wrong time.
I have no issues with spot checks and fines for non-compliance until changing the number becomes automatic.Thats correct, also many driver change trailers on a regular basis, the number in the cab doesnt automatically change as you pick up a trailer
Typo? or some sort of comment on my point?Steel Jessys should be used on heavy plant, and yes you are corrected.
Yeah, right. Anyone making a mistake should be fired. You included, ain't it?
Of course, it all depends on what kind of meter you are using for measurement... 3.5 parking meters would probably be around 1.5x taller than 3.5 metres whereas 3.5 electricity meters would only be about 5 decimetres tall.
I know my parents were taught metric at primary school in Scotland in the 1940s and Scottish O'Grades and Highers were examined in SI units from the mid 1960s. How old are the drivers you are thinking about?
