Leyland Olympian History
Strathclyder
12 Jun 2013
Clydebank
Yes, you are correct, memory has kicked back in, the C-GKE batch ended up with Northumbria and then one or two ended up at Clydeside later on in life
All 3 of the C-GKEs ended up with Clydeside, then into the Arriva Scotland West era. Images below from their CS days (from the Neil Gow, David Devoy & Dunfermline Dave Flickr collecetions respectively).
Journeyman
16 Apr 2014
First Olympians I remember seeing and travelling on were London Country LR class buses. They seemed more modern than the Atlanteans, but quite spartan and crude compared to the London Transport Metrobuses I usually travelled on. I thought they were rather more comfortable and attractive inside, but that's just personal preference. I later rode quite a few of LT's production L class buses, and found them superior to the LRs, so it's clear LT put some effort into making sure they got comfortable vehicles. They had the Ogle Designs split entrance and straight staircase as well, as experimentally trialled on a rebuilt DMS.
JModulo
17 Nov 2013
67A
Dunbar had three Olympians allocated in Eastern Scottish days - LL116/43/59. All passed to Lowland in 1985, with LL160 joining them the following year. When 901/2 arrived in 1987, LL143 was upgraded with coach seats then transferred to Galashiels for use on the 62.
Hopefully 902 will be restored one day.
TheGrandWazoo
18 Feb 2013
Also, there were some examples that Northumbria had that ended up with Kelvin Central at Cumbernauld for the Glasgow expresses
Whisky Papa
8 Aug 2019
One of the differences between those built at Bristol verses elsewhere was the location of the radiator cap. On Bristol built buses it was on the rear at the offside, while later buses has it on the offside at the rear. Both were 'fun' for the vertically challenged to top-up due to being over 5 feet above the ground, which invariably resulted in a lovely trickle of antifreeze down your arm as you struggled with the watering can held above your head :s
The higher radiator cap position compared to a Fleetline led to Yorkshire Rider installing a filler hose system at Todmorden once the NCME-bodied lowheight Olympians arrived there in late 1988 / early 1989 ;).
The other thing that was altered in short order was fitting nylon brushes to the wheelarches. There was something about the aerodynamics of these buses that pulled road dirt onto them in a quite remarkable manner, often leaving all the lower deck windows covered and complaints from passengers being overcarried as they could not see where they were.
MotCO
25 Aug 2014
Metrobus had 5 MAN East Lancs Esteems. The body semed to have larger wheelarches than the wheels required - maybe the MAN had smaller wheels than normal - and these nylon brushes were fitted. They soon got manky and tangled!
Strathclyder
12 Jun 2013
Clydebank
Not sure if they ever served with Kelvin Central proper, but a few ended up in SB Travel private hire fleet and were liveried accordingly. They ended up in the First Kelvin side of FiG (which is what you were referring to I think) before it all was brought under the uniform name of First Glasgow. Believe a few of them lasted long enough to get national fleetnumbers too. Here's C448 BKM in both SB Travel and First Kelvin liveries (from the haley111 & David Devoy Flickr collections respectively).
