Line rover enquiry
102 fan
14 May 2007
Hi
I'm enquiring about rover tickets. My friend And I hope to go to York at the end of April. I'll be using my FIP. Is there a suitable rover for Newcastle to York, taking in Peterborough? Or would it be cheaper to book now?
Thanks
Brian.
David
9 Jul 2005
Scunthorpe
Without checking, apart from the ALR, the only rovers available are the North East 4 in 8 (Berwick - Retford) and the East Midlands 3 in 7 (P'boro - Doncaster). I'm not sure if the latter is valid completely between Doncaster and Peterborough though.
trentside
Fares Advisor
14 Aug 2010
Messroom
The East Midlands Flexirover (3 in 7) is valid between Peterborough and Doncaster on the ECML.
Confusingly, the East Midlands Day Ranger is NOT valid on the ECML except between Peterborough and Grantham.
David
9 Jul 2005
Scunthorpe
Ah! That's the rover I was thinking off that wasn't valid for the full distance between Doncaster and Peterborough.
trentside
Fares Advisor
14 Aug 2010
Messroom
I always have to double check those two as well, the names are similar but areas completely different.
To answer the OP, if you know exactly when you are travelling then you may be best off simply purchasing Advances for a direct journey. If you're looking to do some local travelling in each area, the above combination of rovers would probably be the most appropriate.
