Linslade Tunnel - Why so architecturally elegant?
ABB125
23 Jul 2016
University of Birmingham
Were there ever any plans for a bore in-between the 2nd and 4th bores, or was it always just designed to have 3 bores?
Plenty of space to add an extra pair of tracks, which then saves loads of money compared to building HS2. Why hasn't anyone thought of this before? :rolleyes:
:D:D:D
SargeNpton
19 Nov 2018
The London & Birmingham Railway just designed it with the central twin-track tunnel. The two outer bores came later when the route was four-tracked. That the right-hand bore is so far away from the original tunnel may just have been due to the geological conditions encountered by the engineers.
Philip
27 May 2007
Manchester
Is Shugborough tunnel on the original same line as Linslade? Both portals of Shugborough are quite fancy.
They are indeed fancy, but the Trent Valley Railway was a later and (initially) separate endeavour to the London & Birmingham Railway.
richieb1971
28 Jan 2013
It looks like single line bores were going to be the order of the day but they decided to put 2 tracks down the middle one.
DelW
15 Jan 2015
Might it have been that the last tunnel was built to a slightly straighter alignment, as train speeds had increased from the days of the earlier bores? I suppose it depends whether line speed on 5he down fast is greater than the up fast or not.
Boodiggy
8 Nov 2012
MK
UF and DF both 125EPS for 390s, UF 110EPS for 221s and DF 115EPS for 221s. All four lines are 90mph PS. DF is straighter but very tight transitions either end that end / start in tunnel.
DelW
15 Jan 2015
Thanks, pretty marginal difference then and unlikely to have been of any significance when it was built.
Grumpy Git
13 Oct 2019
Off topic, but the photograph of the speeding Virgin 390 makes me realise how rubbish the Avanti livery is.
Taunton
1 Aug 2013
For clutter read: "Critical infrastructure allowing for the operation of a modern railway"
What is so critical about that overhead structure, which has multiple ladder accesses but seems to have nothing mounted on it.
stuu
2 Sep 2011
It's a signalling gantry with at least one signal attached to it. Signals are usually considered critical to railways
Bristol
The middle bore is the original one, with the single line bores being added later as traffic increased. The bore further out is the down fast, so it's possible that the LNWR were trying to straighten out the bend slightly for non-stop trains. Or just local geology forced the wider bore. The south portal has 2 separate portals, rather than one continuous structure.
I think @Taunton's tongue-in-cheek comment was that a 'modern' railway would be using in-cab signalling.
DJ_K666
5 May 2009
Way too far north of 75A
You can't reopen the line until you're certain nothing will fall onto the line. Easiest way to make sure of that is not put anything up there in the first place! Otherwise you have to pay somebody to sit there for a couple of hours until the mortar has set and then check it hasn't shifted.
Surely they'd have done that before the engineering posession was over. I'm also of the opinion that modern architecture on the railways is duller than a polished turd. That includes tunnels.
Bristol
Yes, the point being that you have to extend the possession to include the drying period. That costs money both in real terms (loss of track access payments, or payments back to TOCs for access not available) and general terms (loss of economic activity). And you have to pay somebody to sit there making sure it's all safe.
Senex
1 Apr 2014
York
That was to suit the then Earl Lichfield of Shugborough Hall (Viscount Anson).
He also had a decorated underbridge built just south of the tunnel on the private access road to the hall.
Evidence of the power and influence of the local aristocracy, just like the tunnel at Haddon on the old Midland line to Manchester. And if you look at some of the very early reports on a route for the London & Birmingham line you'll see the care taken to avoid a couple of major estates not too far away from London. Not disturbing "the seats of gentlemen" does seem to have been quite an important early considerstion! It could all get quite nasty, as the Battle of Saxby (on the Syston & Peterborough line) shewed, as just one example.
Bristol
To be fair to the early railway companies, many of said aristocracy not only had seats in the House of Lords for themselves but had a fair hand in the consituency MP that was returned to the commons, so you can understand why consideration was given to their views.
Grumpy Git
13 Oct 2019
No need whatsoever for a tunnel at Haddon, it wouldn't even have been a deep cutting, (the deepest ventilation shaft is 12'), just the Duke of Rutland insisting the railway was hidden from the hall.
Have a look at the photograph on Wiki to witness the "rise" of the land above the portal.
zn1
3 Sep 2011
Linslade tunnel is always a thrill to enter, the pop of the ears ..on the US as the braking starts on suburban stoppers and of course the DF which is a full tilt max speed run and lets face it...its bloody fantastic on a tilter...
Annetts key
13 Feb 2021
West is best
Hmm, I think being in a curved tunnel (hence you can’t actually see the headlight(s) on the train from any significant distance) on foot, then realising that there’s a train coming (the sound and the sudden change in air pressure and ‘wind’) and then rapidly looking for a refuge ‘hole’ when they are irregularly spaced is a little bit more thrilling…
[Note this method of working is no longer permitted]
I never quite understood how Linslade was allowed 125mph EPS, when Kilsby wasn't, being limited to 110mph PS because of airflow issues.
The single bore DF at Linslade won't have opposing airflow, but the double track UF/DS will - although the DS is limited to 90mph.
Maybe it's tunnel length, or location of vents (if there are any) at Linslade, which allows a higher speed.
Linslade at 262m is not quite long enough to hold an 11-car 390 (266m), while Kilsby is of course much longer at 2209m and has 2 huge internal vent cavities.
QueensCurve
22 Dec 2014
Its a shame that so much clutter was put right in front of it.
19th Century railway engineers built tunnels with imposing portals to calm the nerves of passengers. They though that an imposing portal gave comfort that the whole tunnels was strong enough to avoid collapses.
Sadly some tunnels were fraudulently deprived of adequate brick linings. This included Farnworth Tunnel, Lancashire, and several tunnels on the Tonbridge to Hastings line.
The central bore of Linslade tunnel contains the Up Fast and the Down Slow and therefore has right hand running. There is (or was) a warning notice about that for the safety of staff.
When travelling on the Down Fast in one of those Pendolini, exiting Linslade Tunnel is a good place to observe tilt.
