London advice
15 Jan 2011
Evening,
Heading down from Yorkshire and I've got myself a London Zone 1-6 travelcard for Saturday and will be available for some bashing and shack collecting all afternoon. There's so many options I'm at a loss where to start. What I'd really like to do is get some of the following but am struggling to see if they're possible on the travelcard, any ideas?
90s
HSTs
158s
159s
707s
Kite159
27 Jan 2014
West of Andover
90s inbound from Norwich on Stratford - Liverpool Street services, technically set down only but they are advertised.
HSTs not with a travelcard
158s I don't think run to London normally on Saturdays
159s again hourly service inbound from Clapham to Waterloo, pick up only heading back out
707s, depending when you are down they might be out to play
Hope that helps
15 Jan 2011
Thanks for both of those, will try to utilise both.
On a slightly different angle do you know where I can find a list of which unit types work out of each terminus? Or even a way I could figure this out?
cactustwirly
10 Apr 2013
Hope this helps:
Paddington - Class 165/1, 166, 180*, 360, 387, HST*, 332*
Marylebone - Class 165/0, 168, 68*
Euston - 350#, 378, 221*, 390*
St Pancras - 377/5, 700, 222*, HST*
Kings Cross - 387, 365, HST*, 91*, 180*
Moorgate - 313
Liverpool Street - 315, 317, 321, 360, 379, 90#
Fenchurch Street - 357
Canon Street - 375(occasionally), 376, 465, 466
Charing X - 375, 376, 465, 466
Victoria - 375, 377, 387*, 455, 465, 466
Waterloo - 158#, 159#, 444#, 450, 455, 456(weekdays only), 458
*not within travelcard area
#limited amount valid in travelcard area, double check that it calls at Stratford/Clapham Junction/Harrow & Wealdstone
gazthomas
5 Jun 2011
St. Albans
Hope this helps:
Paddington - Class 165/1, 166, 360, HST*, 332*
Marylebone - Class 165/0, 168*
Moorgate - 313
Canon Street - 376, 465, 466
Great list. No 180 out of Paddington? While not units the 68's out of Marylebone might be of interest to the OP too.
class387
9 Oct 2015
Hope this helps:
Moorgate - 313
There is at least one 168 diagram on the Met calling at Harrow on the Hill, and some Gerrards Cross stoppers can be 168s as well.
15 Jan 2011
Wonder if I could get one of each unit type ........?
Are there others that run in zone 6 that's don't call at any terminus? I'm thinking there is as I seem to remember getting on a 458 at Clapham? I could be wrong however.
class387
9 Oct 2015
Yes, 458s run from Waterloo towards Clapham and Windsor/Reading. The list is incomplete. I will also add 172s from Marylebone, 387s from Paddington and 319s from St Pancras (until Sunday) and Euston (peak only).
Far north 37
13 Apr 2011
you can also get 387s out of fenchurch street and 345 crossrail units out of liverpool street now
15 Jan 2011
Morning all,
Thanks for all the advice on the thread, was much appreciated.
I'm not one to write trip reports, yet, but thought you might be interested in what/where I ended up. Learned a lot as well, got caught up early on getting shacks in rather than units, so many easy potential moves to make found myself stuck on the same line refusing to let a shack opportunity to gt away. Wish I'd spent more time out of Liverpool Street and had realised that Limehouse was shut after getting the DLR to it.
05:43 from Wakefield
91109 WKF KGX
700014 STP BFR
700046 BFR EPH
Burgess parkrun
700025 EPH HNH
700010 HNH LGJ
700012 LGJ STE
700003 STE TUH
455809 455806 TUH GIP
455820 GIP SRH
455832 SRH WNW
455801 WNW WSW
455811 WSW BAL
455816 BAL SRC
455805 SRC CLJ
450553 450040 CLJ BNS
455729 455705 BNS PUT
458534 458526 PUT CLJ
444021 444035 CLJ WAT
Waterloo is chaos.....
458516 458518 WAT VXH
455729 455705 VXH CLJ
378136 CLJ PMR
455824 455821 PMR QRP
378148 QRP SDE
DLR to Limehouse the Poplar then Stratford
315818 315825 SRA LST
90008 LST SRA
90014 SRA LST
walk to Moorgate (what a dump)
313035 313040 MOG HGY
313036 313045 HGY FPK
365539 FPK KGX
43277 43314 KGX WKF
17:35 back to Wakefield
class387
9 Oct 2015
Nice trip!
You probably shouldn't take Class 90s from Liverpool Street to Stratford though. Other direction is fine.
ash39
8 Feb 2012
20 winner stations is a good effort!
I need to get myself to London soon.
