The Silvertown tunnel will be paid for by drivers using it AND the current Blackwall tunnel. No such charging mechanism exists for a pedestrian/cyclists bridgeYes, thanks
But they are major very expensive projects!
There are several YouTube videos showing brave souls attempting this.You could walk through the tunnel, if you didn't mind being suffocated
I've seen cyclists, they didn't seem very happyThere are several YouTube videos showing brave souls attempting this.
Baker Street eastbound Circle/H&C the 7th car doors are inhibited in SDOIs there any SDO on the underground where an entire carriage is out of use? I know some stations only have 1 door open in an end carriage
I think it would be extremely difficult to make it pedestrian and cyclist friendly without banning car traffic from it (or only allowing it as EVs and in one direction only), but if it was made pedestrian and cyclist only, it would be fairly easy to just cone off the entrances and put "no vehicles" signs up. It could be made nicer later.
That's true. I'm guessing the ULEZ doesn't cover it? Or if it does then it doesn't really help? I'm not super familiar with London transport policy, especially when it comes anything on roads! Quite, I still haven't read the revised Highway Code yet despite it being rather beneficial for me.
Even if the ULEZ does cover it (I think it doesn't now but will in due course) a gobful of Euro 6 diesel fumes is still a gobful of diesel fumes. It's still going to be grim for a cyclist or pedestrian until zero-emissions vehicles are used.
Rotherhithe road tunnel, if turned into pedestrian and cyclist only usage, what would the diversion for other road users be like? Would it be a big diversion around it, possibly becoming an issue elsewhere?
especially Rotherhithe as it closeness to Canada water also cause potential capacity issues in terms of max train frequencies
IIRC you have to pass through the gatelines, so needing an Oyster or debit card, but if you exit the system at another terminal the card isn't charged a fare.
For that pattern of use, they would need to be "No motor vehicles" signs.I think it would be extremely difficult to make it pedestrian and cyclist friendly without banning car traffic from it (or only allowing it as EVs and in one direction only), but if it was made pedestrian and cyclist only, it would be fairly easy to just cone off the entrances and put "no vehicles" signs up. It could be made nicer later.
Especially with the Woolwich Ferry being a complete fiasco, riddled with either technical failures or industrial actionEither over Tower Bridge, or east to Blackwall. Neither is good, so for people driving local journeys in the east it would be terrible, and a complete non-starter
When I 'were a lad', I used to cycle through Rotherhithe Tunnel. The traffic moved faster than 20mph in the '50s/'60s because there was less of it but I usually cycled on the pavement down the ramp and carried the bike up the spiral staircase on the other side to get out. Personally i think there would be a very good case to stop all ICVss using the tunnel and only permit EVs up to a certain size along with cycles and pedestrians. If the ventilation is needing replacement, removing ICVs would allow a lower rate of air change on any replacement system. It would of course be a very useful reminder to drivers that EVs are the future of tunnel traffic.There is on the overground at the two station concerned already. Going through multiple carriages is seen a non-starter given the loadings at certain times.
Reopening the pedestrian entrances (spiral staircases) closest to the river would be much more pleasant and reduce the underground walking distance by 750m and make the route far less diagonal across the Thames.
The diversion for cars and lorries would be huge and unacceptable. The distances involved would be large and consequently would cause a substantial increase in vehicle emissions.Rotherhithe road tunnel, if turned into pedestrian and cyclist only usage, what would the diversion for other road users be like? Would it be a big diversion around it, possibly becoming an issue elsewhere?
Even if there was a pedestrian route, no one would cross because of the distance. However, there is a cheaper option available if Liverpool would change the zones so the Wirral line on the Liverpool side was somehow area B. Then a 1 area Day ticket is £1.40, which seems reasonable to me for a river crossing.Liverpool – the Wirral has no pedestrian route and you have to pay for the train, bus or ferry or a toll if you drive through the Mersey Tunnels.
Early in the history of TfL's mismanagement of London's road system, Rotherhithe Tunnel was closed for repairs for an extended period. It caused traffic chaos and TfL caught a lot of flack. A little later the tunnel needed to be closed again and Nick Ferrari questioned the then head of TfL, whose name I can't remember, - it may have been Derek Turner - about this. The response was that TfL had learned the lesson and that massive penalties would be incurred by the contractor if the work ran over schedule. In other words, the anti motor car TfL recognised that closing Rotherhithe Tunnel had severe consequences.
year | origin | destination | typical autumn weekday volume |
2016 | Rotherhithe | Wapping | 73 |
2016 | Wapping | Rotherhithe | 72 |
2017 | Rotherhithe | Wapping | 70 |
2017 | Wapping | Rotherhithe | 68 |
2018 | Rotherhithe | Wapping | 90 |
2018 | Wapping | Rotherhithe | 83 |
2019 | Rotherhithe | Wapping | 92 |
2019 | Wapping | Rotherhithe | 84 |
2020 | Rotherhithe | Wapping | 37 |
2020 | Wapping | Rotherhithe | 36 |
It would actually be less than £264, since the figure of 176 includes travelcards and concessionary travel.In 2019, say, there were 176 journeys daily.
Charged at £1.5 = £264.
I did make an FOI request to find out the amount of journeys between Wapping and Rotherhithe on the Overground, and received back what I've pasted below.
The number of daily journeys seem very small to me (compared to other journeys on the network)
Assume the same volume is maintained throughout the year inc weekends, the total revenue for the year comes to £96,360.
This must represent a drop in the ocean for tfl (maybe a knowledgeable member of these forums can confirm/qualify).
And this amount would , I suppose, easily be offset by the increased economic activity, footfall and utility generated by helping to knit together more closely the London boroughs of Tower Hamlets and Southwark.
I believe this is a good, novel idea which really should be taken forward by someone/group who knows how to navigate/achieve this outcome
Can you list for each of the last 10 years the number of journeys taken on the Overground between Wapping and Rotherhithe, and the revenue generated from these journeys.
Can you rank the revenue generated from this journey in comparison to other TFL journeys on the tube, dlr and Overground in order to demonstrate a relative measure of revenue-generation. For example, you could list the highest revenue-generating journey and amount along with the journey with the lowest such measures, or in any other way that you can easily formulate.
Please see the table below, which gives modelled estimates of journeys between Wapping and Rotherhithe stations in each direction on a typical autumn weekday. We only hold data back to 2016.
year origin destination typical autumn weekday volume 2016 Rotherhithe Wapping 73 2016 Wapping Rotherhithe 72 2017 Rotherhithe Wapping 70 2017 Wapping Rotherhithe 68 2018 Rotherhithe Wapping 90 2018 Wapping Rotherhithe 83 2019 Rotherhithe Wapping 92 2019 Wapping Rotherhithe 84 2020 Rotherhithe Wapping 37 2020 Wapping Rotherhithe 36
Fares revenue is apportioned by mode, not by origin and destination station, so we do not hold the revenue data requested.
