London Thameslink - London Terminals confusion
grove
22 Aug 2014
I travel intermittently on weekdays, off-peak from the Arun Valley line to St Pancras. The map of the route here https://www.nationalrail.co.uk/times_fares/ticket_types/Travelling-to-London.aspx#Terminals says that in order to make his journey you need a "London Thameslink" ticket. However, when you attempt to purchase said ticket on the Southern website it recognises the London Thameslink ticket but actually sells you a London Terminals ticket. Have the two now been merged and is the National rail website out of date?
My London Terminals ticket operated at St Pancras without any problem.
Thanks.
No, they have not been merged. You need a London Thameslink ticket to go to Farringdon or St Pancras from the south. The fact that the barriers accept a London Terminals ticket at St Pancras is not an indication that it is valid there, just a limitation on the programming of the barriers.
grove
22 Aug 2014
So how do you actually purchase one for the future? I kept screenshots of the process as it switches from "Thameslink" to "Terminals".
Hadders
27 Apr 2011
This is very poor from SWR.
I’d try an alternative retailer or specify that you’re going to Farringdon, which isn’t a London Terminal so the London Thameslink ticket should be sold.
It is Southern.
I had a look at the booking website. It shows two identical fares, one with the ticket apparently issued to the relevant station, and one issued to London Thameslink. However, what the OP appeared to indicate was that it was issuing a London Terminals ticket even when London Thameslink is specified.
https://ticket.southernrailway.com/...wCheapest=no&step=outward-fare&tocSpecific=no
However, the price of £29.70 for an off-peak day return appears to correspond to the London Thameslink price. The London Terminals price is £29.60.
Alex365Dash
2 Jul 2019
Brighton
I'd still be careful there - there are fares set from e.g. Arundel to Farringdon specifically as well as London Thameslink, so you'd still need to have the correct destination on your ticket!
EDIT: as well as, not rather than.
Hadders
27 Apr 2011
It is Southern.
My bad :oops:
In that case GTR really ought to know better.
I'd still be careful there - there are fares set from e.g. Arundel to Farringdon specifically rather than London Thameslink, so you'd still need to have the correct destination on your ticket!
BR Fares suggests they are issued to London Thameslink.
Haywain
3 Feb 2013
My bad :oops:
There are fares to London Terminals, London Thameslink and London St Pancras. Goodness knows how a retailing site is meant to distinguish them. However, the OP might want to consider buying a ticket to Kentish Town which would remove any risk of ambiguity and give extra validity.
alistairlees
29 Dec 2016
Thanks.
Can you put your journey details in so the problem can be investigated?
- where from?
- date of travel?
- time of travel
- single or return?
grove
22 Aug 2014
- where from?
- date of travel?
- time of travel
- single or return?
- where from? Horsham
- date of travel? 23/01/2023
- time of travel 0855
- single or return? Return
alistairlees
29 Dec 2016
Thanks. I may be missing something, but the return tickets I see at southernrailway.com for this journey (and with a return time of 17.00 on the same day selected, with one adult and no railcard) are:
- £26.80 Off-Peak Day Travelcard (not valid on Gatwick Express)
- £29.70 Off-Peak Day Return to London St Pancras (not valid on London Underground)
- £29.70 Off-Peak Day Return to London Thameslink (not valid on London Underground)
- £35.80 Off-Peak Day Travelcard
- (various singles and 1st class options, not included here)
I don't see any fare to London Terminals (that is valid to London St Pancras; there is one but it's only valid so far as City Thameslink, so doesn't show here).
This is a route that is ripe for massive fares simplification.
I haven't bought the ticket, but when it's in my basket I don't see it changing from London Thameslink either.
Am I missing something?
grove
22 Aug 2014
This is interesting then. If I enter "London Thameslink" 0900 out, 1700 return I get a fare of £25.20.
When I click "Add to basket" the fare remains the same but the ticket becomes "London Terminals".
Deerfold
26 Nov 2009
It may not be obvious to the average punter unfamiliar with the three letter codes for stations, but that's showing you trips to London Bridge and is then selling you a (correct) ticket to London Terminals.
Haywain
3 Feb 2013
Presumably because selecting London Bridge is seen as the first available station in the London Thameslink group.
grove
22 Aug 2014
So you select "London Thameslink" from the available options and it translates it to "LBG", thereby giving you possibly an incorrect fare. Is there a code for London Thameslink?
It all feels like a poor bit of coding behind the scenes. Designed maybe to 'simplify' but then introduces an error!
Haywain
3 Feb 2013
The problem (if it is a problem) is that journey planners are generally designed to give the fastest journey available and that is achieved by giving results to the first of the group that the train comes to. If you want to go to Waterloo from Horsham would you just select London Terminals? No, because you wouldn't get those results. In the same way if you want journeys to St Pancras you need to select St Pancras as the destination station.
AM9
13 May 2014
St Albans
I don't think there are station codes for the following groups of stations but they are all part of specific flow destinations:
London Thameslink has a flow destination of 4452 (which includes all the TL core stations plus Euston)​
London Terminals has a flow destination of 1072 (which includes all the TL core stations except elephant & Castle and Farringdon)​
London Zones 1-6 has a flow destination of 0035​
plugwash
29 May 2015
The problem is IMO twofold.
1. Planner based sales systems are oriented primerally around selling the cheapest tickets for inflexible journeys. They sell flexible tickets as well but it feels something of an afterthought. So rather than the flow being "select an orogin and destination, see a list of tickets and buy one" the flow is "select an origin, destination and time, see a list of trains between that origin and destination and then see tickets that are valid on one of those trains.
2. London has an exceptionally messy fares structure, with overlapping station groups, and the rule that a London Terminals ticket is only valid to arrive in London not cross it.
If a user specifically asks for "London Thameslink" they probablly want a ticket that has the flexibility to travel to any thameslink station but that simply doesn't fit the model of planner based sales.
Haywain
3 Feb 2013
If a user specifically asks for "London Thameslink" they probably want a ticket that has the flexibility to travel to any thameslink station but that simply doesn't fit the model of planner based sales.
They might well want that flexibility but how would the journey planner know which station is the destination?
AM9
13 May 2014
St Albans
Why would it need to know, the stations that a London Thameslink ticket is valid to/from is well defined. All trains that pass through the core stop at all stations in that route through the core.*
*Euston is the exception but that would require a separate itinerary
