Joseph T
Which of the two is best for a trip from London to Birmingham: LNWR or Chiltern?
Define 'best'.Which of the two is best for a trip from London to Birmingham: LNWR or Chiltern?
"On a budget" would suggest cost, and for that I would say it's pretty evenly split. I've had advances from less than £10 on both TOCs, so I'd recommend looking on both's websites for the cheapest fare.Define 'best'.
Are you looking for comfort, cost or journey time?
Cheapest walk up, semi-flexible, fare (no railcard) likely to be the £36-40 Super Off Peak return (route via High Wycombe) with Chiltern. £23-95 with railcard discount.Which of the two is best for a trip from London to Birmingham: LNWR or Chiltern?
Exactly, which is why I asked the OP to clarify their definition of 'best'. The Chiltern Mk3s seem to be well-rated on comfort, but of course, the limited times these run won't necessarily suit. Though also, certain varieties of 350, not the 3+2 ones outside ex-First Class anyway!"On a budget" would suggest cost, and for that I would say it's pretty evenly split. I've had advances from less than £10 on both TOCs, so I'd recommend looking on both's websites for the cheapest fare.
LNR will tend to have longer trains, usually 8 (but could be 4 or 12) carriages, and they run on electricity, whereas Chiltern use diesel units with underfloor engines or sometimes very loud locomotives. However, there is a risk of getting a 350/2 with 3+2 seating, no tables and no plugs - but if you do (and there's only a 20%ish chance of getting an eight car unit with BOTH portions 350/2) the declassified first section has these.
It all depends.The Chiltern Mk3s seem to be well-rated on comfort
