Loop Lengths
MarkyT
20 May 2012
Torbay
"A loop has only one signal section - two signal sections or more is a slow line." - R. Sumner.
As to loop entry and exit speeds, most freight can reach over 40mph (on the flat) in the length of the train, so 50 turnouts are a better choice, IMHO. Therefore the toe to toe length of the loop is the toe-to-CP for the entrance T/O +, 775m (train) + 2x20m (loco and demic) + 5m (inaccurate stopping) + 20m signal standback +a signal overlap (nominally 180m, can be a bit shorter at 50mph) +CP-to-toe for the exit T/O.
The more signalling engineers you put in a room the bigger the bill ...
On the other hand, if you get a good one in right at the beginning before PW and structure designs are finalised, you can often avoid a lot of rework and cost! Extra points for good coverage of overlap considerations Mr. Locke. Sometimes it might be possible to put in an overlap spur with a friction buffer stop in lieu of the full overlap length, if further lengthening at either end is particularly difficult.
Joseph_Locke
14 Apr 2012
Not a first choice: RAIB Bromsgrove,
