They ride roughly enough as it is, you'd have to be crazy to try and get anything more out of them!
For ride, I'd pick one over a Pacer any day. Possibly even a 323, too. (As a passenger, of course)You want to try being up front on them, the ride is worse there. They are without a doubt the worst riding passenger rail vehicle that has ever operated in this country.
I find that slightly bizarre having spent the last 8 years being thrown about by them every day. They make a Pacer look like a Rolls Royce.
You feel every little issue with the track, they don't insulate you from anything. They also have a nasty habit of transmitting vibrations up into the body when negotiating curves.
With the oldest ones over a decade old, have they suffered from any problems structurally? The rough riding must batter the body and underframe daily. I know at that age, and often earlier there rubber-tyred counterparts tend to be suffering structurally.
Some very interesting feedback here. I have found the M5000 to be quite loud at high speed, potentially due to their odd wheel profiling; and their bogies are generally distasteful. I would think the M5000 bogies are responsible for speed limits across certain sections of the tramway being reduced after its introduction, ironically making the older T68 fleet possess some advantages over the M5000. Though, as a passenger, I’ve never had much issue with its ride quality.
Another interesting thing to note: I rode a 31xx tram the other day and noticed it sounded different to the normal M5000s. Do they (or any tram batch in that series) have new or re-engineered traction motors that would explain the difference in sound?
Oh wow, whiny gearboxes? I didn’t notice. Is it all trams in the 306x series? Odd. I’ll have a look at some point this weekend. I may not be able to “unhear” it ever again.
Additionally, some portion of track in the Rochdale line seems to be reprofiled, due to the even more odd run sounds M5000s make on it. Do you have any idea which portion of that line is reprofiled?
That's why they were bought, the high speed sections on the Oldham and Rochdale Line were devised to keep the local delinquents out of trouble by entertaining them on a reasonably- priced rollercoaster rideYou want to try being up front on them, the ride is worse there. They are without a doubt the worst riding passenger rail vehicle that has ever operated in this country.
Ah, interesting. I've had a look down that line and blimey it's loud. I've attached a recording for those who haven't heard it. (the recording is protected by copyright and cannot be used for anything)
Speaking of sounds, at which speeds do the M5000s change phases? (if it's a three-phase motor I'd assume there were two specific speeds at which the motor switched)
Additionally, I have noticed this screeching sound that happens every so often at certain speeds. It is difficult to describe other than it is a screeching sound that lasts for only about a mile an hour and happens every so often. I have attached an image of the spectrogram of one of my recordings, and have highlighted what those frequencies seem to be. I have also attached a recording which is of the selected audio in the spectrogram. There are 5 screeches within; some distinct (namely the first) and some not.
What on earth is it? And at what speeds do they occur?
Ah. Pardon me, I’m not exactly a rail professional. I’m undertaking a project which requires me to have some level of understanding with certain areas of the M5000.I don’t believe that’s how an AC motor works, the three phases are used at the same time continuously. They don’t switch between phases.
I’m not sure what the screeching sound you describe is, I can’t quite hear what you’re referring to. The recording is of a bogie with whining gearboxes though, so if it’s what I think you’re referring to, it’s just worn gears.
How do the M5000 gearboxes work? if applicable, do you know of how many gears there are and at what speeds they change at?
What a fitting term.They just have the one gear, it’s technically a final drive, but they’re referred to as gearboxes.![]()
Is the screeching sound not low speed hunting? Sounds like a mostly straight piece of track with the wheels just being gently nudged back to true every couple of seconds.
Failsworth to Hollinwood is my favourite bit of the whole network, in both directions! Absolute blast lol.That's why they were bought, the high speed sections on the Oldham and Rochdale Line were devised to keep the local delinquents out of trouble by entertaining them on a reasonably- priced rollercoaster ride![]()
Agreed, but I would extend that to Victoria from the Failsworth end as the Monsall to Vic run is quite lively too.Failsworth to Hollinwood is my favourite bit of the whole network, in both directions! Absolute blast lol.
The 5mph crawl through S&C out of Victoria outweighs that I think!Agreed, but I would extend that to Victoria from the Failsworth end as the Monsall to Vic run is quite lively too.
Oh, yeah, Collyhurst tunnel is pretty fun though, not as good as the hilliest bit round Hollinwood, but still fun.The 5mph crawl through S&C out of Victoria outweighs that I think!
Oh yeah I've been through Pomona a few times - seems closer to 1/2mph than 4mph. Very bad either way.If you’re looking for a crawl, head over to Pomona where any point on the junction has been plagued with a 4mph TSR. It’s fun, and even more fun on trams with whiney gearboxes. You hear a hum very near 100hz, where the traction motor sounds eventually attenuate down to as speed tends to 0.
Metrolink has this unfortunate habit of copying the heavy infrastructure costs of heavy rail with big bridges, etc while taking on the compromises of light rail with tight curves and street running, etc. I'm not saying that the system should never have been built, but that we should really be aware to try and not end up with a "worst of both worlds" scenario when constructing future extensions. The Trafford line was certainly an improvement on something like Eccles, or even say Ashton, but it does not feel as fast as it should be to provide a truly competitive connection.
