DasLunatic
- Joined
- 11 May 2015
- Messages
- 696
As frequently stated on threads, the usage of MkIII coaching stock will not be permitted post-2020. Chilternising stock is also very expensive, and can only be done at one or two depots in the country.
Therefore, could powered hinges be installed which only open when the accessible buttons are pressed? This means the locking mechanisms will not need to be replaced, and doors can be closed simultaneously from the guard's compartment or the DVT. The hinges can be installed in any depot and there is no need to completely replace the door structure.
Powered hinge doors can be seen on rolling stock in Germany, where it is used in their fleet of N-Wagens.
Am I spouting complete shash, or is this a viable solution to making MkIIIs accessible?
