Maybe to deter the good folk of Wythenshawe from becoming as cable thieves![]()
About 90% of the track is in place. The overhead wires have only begun to appear in the last week or two but some quite long lengths are up. The signs don't say the wires are live, they say they should be treated as live, which is not quite the same thing.
It has been suggested on SSC that the reason the work is so far ahead of schedule is that as other lines have been completed, the contractor has moved workers and equipment to the airport line instead of laying them off.
Even when the obvious physical works are finished, there will still be a lot to do before a service can start, but I think we can still expect it to be well ahead of schedule.
The general view on SSC is that the service will initially run between the airport and Deansgate-Castlefield until the full opening of the Second City Crossing in 2017 increases capacity through the centre.
Went into Wythenshawe today and was surprised to see the wires up, complete with warning signs that they were live! Surely not, there's two years to open date!
But how will the airport line teams be able to run as far as Dransgate-Castlefield if the line is congested north of Cornbrook?
Ok, so we should be safe for the foreseeable future. The Port Salford line and the extension from East Didsbury to Stockport are the only expansion projects likely to ever be built.
What is the source of your information that backs up this statement
Has that 42tph figure taken into account, well, passengers![]()
There isn't the capacity into the city for any more...
If you wanted more you'd be needing to change the line to alty back to Heavy Rail and re-opening Central for CLC and Mid Cheshire services...
Or diverge from 2CC at John Dalton Street, interchange with Salford Central, and run to Bolton via Salford University & Pendlebury...(!)
Presumably the statement about turning back at Deansgate/Castlefield refers to the future remodelling when I think trams can reverse in a platform loop, not the current situation when they have to turn back on the main line.
Nothing official has been said so far to suggest the airport line will open earlier than summer 2016 but common sense suggests something will open early. It would be very bad PR to leave the line complete but unused, and in any case if they waited for 2CC to be completed they'd have to wait until 2017.
Well, the nearest system to Metrolink outside the core IMO with anything near 40tph would be the DLR that uses ATP very close to line of sight with similar size trains.
(The Jubilee and Northern line use these but are much bigger and only manage 33tph tops).
I'd honestly say anyone shooting above 30tph on a segregated network needs to think very carefully about how they'll manage it, with something as unpredictable as Metrolink I really dowbt it will manage a reliable regular service, in part as to it doesn't manage one now at 20/25tph.
I'm frankly amazed that the ridiculous MediaCity - Velopark thing is still ongoing I would have thought this would have ended by now if the Cornbrook turnback is in full working order.
Are they still not turning back at Piccadilly even now that TMS is online?
I seem to remember seeing somewhere a statement that its capacity would be 84 trams per hour in both directions combined, which would mean 42 each way, which is more than one every 1.5 minutes.
However that wouldn't be needed in the near future - as you say it would work out to 30 an hour at what Metrolink calls peak periods (most of the day on weekdays): 10 to Altrincham and 5 each to Eccles, Media City, East Didsbury and the airport.
The next line they are hoping to build is to Trafford Park and the Trafford Centre, which would also feed into this section!!
And I'm becoming more sceptical towards light rail expansion in general. When it comes to big projects, I don't think the capital costs can be justified when the gains are roughly equivalent to those you'd get from investing in local bus services. And light rail can actually have a negative effect on towns that lose their heavy rail services because of it. Bury, Altrincham and Oldham are clear examples of that.
With regards to the EML it is ridiculous. Why did they design it so that the reversal takes park in Velo Park stop? There is plenty of room for point work to connect the outbound line to what could become the turnback siding in the middle of the running lines, ala Timperley. Before the EML opened 20 services per hour used to turn back at Piccadilly (Bury, Alty, Eccles, MCUK) but there were to terminating 'sidings'. It is shame that such capacity could not be built in to the new Sheffield Street turnback.
So 40 in total through Cornbrook platforms, although the MCUK may eventually terminate at Cornbrook meaning only 35 go forward to D/C.
Because it was only really designed for special trams to reverse there during events at the Etihad during which velopark would be closed so it wouldn't really matter. However MediaCity trams run to Piccadilly so need to reverse somewhere, with Sheffield Street not built for the extra 5tph the nearest turnback was Veloppark. I still don't understand why it's used and not cornbrook as advertised afterall it is where peal paid for them o terminate.
Firstly, trying to get a tram full of people from media city onto one of the city bound trams during the peaks would be nigh on impossible.
Secondly, the fact that they have been running through to Piccadilly would mean there would be a few angry people if we suddenly caped them at cornbrook.
The second reason is actually why they need to get on and turn them there asap. The longer they leave it the worse it will be when it eventually has to happen! That level of service is the one enough trams were ordered for, the infrastructure was built to cater for and the developers paid for in their agreement with Salford Council! And it would save all that mileage on doing Cornbrook - Velopark and back however many times a day.
