Manchester Piccadilly P15-16 - my idea for an alternative
From the Northern timetable thread:
A complete side-thought here...would it be more affordable than the full P15-16 project to deck over the area between 13-14 and the Picc trainshed and provide 2 or 3 5-car west-facing terminal platforms instead?
DarloRich
Fenny Stratford
Do you mean that "V" which seems to hold a taxi rank/car park?
Altfish
16 Oct 2014
Altrincham
I think you'd find that it'd cost almost as much for half the benefit. And without some significant demolition of properties you are going to end up with fairly short platforms.
Bantamzen
4 Dec 2013
Baildon, West Yorkshire
Plus, if that were to go ahead what would be the point of the Ordsall Chord? Until P5 closes at Manchester Oxford Road there are effectively 3 terminating platforms anyway, with most through services using only 2 of them. So you'd be replacing almost like for like, just moving the terminating platforms east to Piccadilly with all the extra signalling & points work that would be involved, not to mention conflicts between terminating and through services there. It would be far better to stick with the notion of a P15 & 16, using these for westbound and 13-14 for east/southbound services.
The point of the Chord is to give access to Oxford Road and Piccadilly, isn't it? The Airport is a weak argument if you look how lightly loaded trains past Picc are.
(Not that I agree with the Chord given limited funding - if it was either-or, as it seems, P15/16 would have been more beneficial - but that's been done on another thread).
lejog
27 Feb 2015
While you continue to believe that the passenger numbers were the basis for the Northern Hub business case, instead of the real world business case, you'll believe that that the "Airport is a weak argument". Unfortunately in the real world if your arguments were used, there wouldn't have been any investments. However often you wish to post them on these forums, fortunately your arguments lost 7 or 8 years ago.
What business case is there for passenger rail improvements other than passenger numbers?
I personally believe it was a vanity project put into place to appease the North with little practical insight into how people actually use the network around there, having grown up using the North West's rail network intensively for the first 22 years of my life.
driver_m
8 Nov 2011
The issue is just as much outside the station as the station itself. 11 and 12 are the prime example of this as they are underused because of the need to go through platform 9 to get there, and needing a path to cross pl13. Pl15 and 16 are the only real game changer in town. Grayling is talking out of his backside thinking he can do a Thameslink style core run through 13 and 14 as this just wouldn't allow for any expansion of long distance services i.e WC to Bolton, reintroduction of XC going north. They take up too much time on those platforms.
keith1879
1 Jun 2015
Existing passenger numbers don't make the case - it's potential increases. Now I accept your view that Manchester Piccadilly is a much more significant destination than the Airport (for rail passengers at least) but in general terms I doubt that West facing platforms at Piccadilly would be hugely useful. Through trains to various destinations (airport included) will always generate more income.
FWIW I have long stood on P13 in the late 90s and thought you could close 11/12 and squeeze in a 3ish car P12 through platform on its approach trackbed. But I think the need for longer trains would have removed the value of it by now.
The other cheaper thing you could potentially do on 14 (only) is add a shorter bridge half the length of 14 which would allow arrivals into the two halves to occur independently a bit like the long platform at Chester.
keith1879
1 Jun 2015
I too think that a third through platform could be squeezed in ....but I suspect that the cost would be in the same ball park as the proposed 15/16.
I doubt it would be anywhere near as much as it wouldn't require 240m or thereabouts of new bridge. But it'd be quite short so possibly not much future use.
WatcherZero
25 Feb 2010
You still have the issues of trying to path on the two tracks through Oxford Road and Deansgate, all you do is remove the bottleneck through the Piccadilly platforms at the loss of direct services
keith1879
1 Jun 2015
Sorry - I missed the 3ish car bit. I was assuming a full length platform but starting under where the roof is now. I agree that a "shorty" as you describe could be done much easier but as you say - to what purpose?
Jonny
10 Feb 2011
There is the space and potential for a loop/chord from the P13 track, maybe after 386 signal, feeding into 374 signal (at the end of Platform 9 and acting as the final outlet signal for Platforms 9 to 12 inclusive), although whether or not it would be worthwhile is another matter altogether. It would probably be of more use as a supplementary measure to extra platforms than a substitute anyway.
lejog
27 Feb 2015
I've tried explaining to you several times, the latest in the Northern May 18 timetable thread this morning, why passenger numbers were not the prime factor in the business case for the Northern Hub. The investment depends on payback to the government from tax on increased economic activity in the North from the whole economy, not just the small % of the economy represented by the rail industry. As is also true with the business cases for HS2, NPR etc. I've also in the past posted links to documents where this is explained.
You are welcome to your personal beliefs, but while you fail to understand the reasons why decisions are taken in the real world, they won't reflect what happens in the real world. If you base your beliefs on poor quality anecdotal evidence like your personal experience, then again they won't bear much relation to the real world. Its interesting you talk in terms of believing, given the dictionary definition of "accept that (something) is true, especially without proof" ......
I'm sorry, I cannot and will not accept that - what it says is that there is only one macro-level political approach that is valid (the one that was taken), and that clearly is not the case.
The "Northern Hub" thing has in my view been a sop from start to finish and has addressed little or no real-world problems effectively. Just like HS2 north of Birmingham[1], the money spent on which would benefit provincial cities if it were instead spent on giving them all a German standard of fully integrated city transport system.
[1] I believe it is needed south of Birmingham to provide an additional 2 WCML fast lines to ease capacity. That capacity constraint is much less of an issue north of Birmingham and so the case is much weaker.
Ianno87
3 May 2015
The economic case for HS2 is stronger north of Birmingham through counting the wider economic and growth benefits (e.g. Airport City at Manchester) of HS2 links stimulating business to business connectivity.
lejog
27 Feb 2015
Its pretty obvious that you won't accept that from your continued refusal to consider any factors outside passenger numbers, or trivia such as the number of DMUs freed up, the distance passengers have to walk or whatever. Of course there are many valid macro-level approaches possible, however a smaller number that meet the targets set for a project and even fewer that meet them in an optimum manner.
The Northern Hub addressed its initial objective of attracting investment to increase capacity into and through Manchester within a realistic budget with the optimum business case (which also optimised the economic benefit to those of us living in the North). If the increase in southbound paths from Piccadilly and the doubling of capacity at Victoria doesn't address a real-world problem, I don't know what does.
Where are the facts and figures to back up your "view" that money would be better spent on a German standard of fully integrated transport? If you have any facts, figures, research etc that backs this up, I'd be very interested in seeing them, until then they remain your views or beliefs, lacking any proof. As Ianno87 correctly says the business case for the full HS2 network including wider economic benefits is higher than Phase 1 alone, capacity constraints are only part of the overall picture so your assertion that the case is much weaker north of Birmingham is untrue.
Source: National Audit Office 2016 HS2 report
PR1Berske
27 Jul 2010
There's no economic case for HS2 anywhere, in truth, but particularly up here where it'll be too far in the future before an inch of track is laid. P15/16 would benefit us far better than HS2.
LOL The Irony
29 Jul 2017
Chinatown, New York
Here's what I'd do.
Demolish Deansgate's platforms, Add 2 extra through platforms at both Piccadilly and Oxford Road and 4 track it to Castlefield Jct where 2 split to Liverpool and 2 continue North to Bolton. Then add a walkway to Oxford Road to link the Trams or if you want to skimp out, tell passengers to use Piccadilly for Metrolink services.
DanNCL
17 Jul 2017
County Durham
Here's what I'd do.
Deansgate has the advantage of through services to destinations on Metrolink that Piccadilly doesn't, though otherwise I can't see any reason for it not to close
Altfish
16 Oct 2014
Altrincham
Here's what I'd do.
I can't argue with any of that
WatcherZero
25 Feb 2010
It used to be the main station for Deansgate area shoppers and workers, but as the service calls have been reduced Salford Central at the other end of Deansgate has kind of taken over that role.
Extending Oxford Road platforms to 240m towards Deansgate, closing Deansgate and adding a walkway would probably be the best bet, though expensive. 4 is quite enough, platform 1 is barely used as it is. Changing to two islands would be a better option if possible, one island in each direction, though as a listed building it's probably not possible.
LOL The Irony
29 Jul 2017
Chinatown, New York
I can!
Which buildings would he demolish?
Why does he think Oxford Road needs six through platforms but Piccadilly only four?
The first answer is all that's needed and turn the remaining empty space into affordable & social housing and homeless shelters.
The second awnswer is ooops...
