Manchester Piccadilly to Sheffield: do trains run via Stockport?
xtradj
24 Jul 2006
Can anyone tell me that trains from Piccadilly to Sheffield go via Stockport and hazel grove?
I have seen videos of emt and ftp going via redditch North and marple? Which has now confused me as if they go via there then has the route now changed? It still says they call at Stockport which adds to my confusion
3 Mar 2013
There were diversions two weekends ago so it may be these that you are seeing?
Starmill
18 May 2012
Bolton
There are a handful of trains including empty stock that go that way at certain times of day. Most do not because of the need to call at Stockport.
40129
23 May 2014
That's one heck of a diversion!
Ps: I know you meant Reddish North but it was too hard to resist
bb21
Emeritus Moderator
4 Feb 2010
Northern generally go via Reddish North, except the last one towards Piccadilly Mon-Sat.
Merseysider
Fares Advisor
22 Jan 2014
Perhaps have a look at Real Time Trains. The info would be accessible there.
RTT is a great website but it does have limitations. Quite often when a train is diverted at short notice, the new route won't be shown, just "No report" or "Not stopping" next to its original calling points, such as the example I've attached when my local stoppers were being diverted via Stockport.
martynbristow
15 Jun 2005
Birkenhead
Generally its possessions forcing it the other way but crews also need to keep the route knowledge so the odd diagram will be timetabled that way e.g 5M06 does which is ECS to Lime Street and a similar TPE which is worked from Sheffield and another EMT & TPE in the evening back.
Good luck getting pictures as its very odd hours :P
PHILIPE
14 Nov 2011
Caerphilly
RTT is a great website but it does have limitations. Quite often when a train is diverted at short notice, the new route won't be shown, just "No report" or "Not stopping" next to its original calling points.
RTT would show the booked timings
louis97
14 May 2008
Derby
Not that these limitations are exclusive to RTT. Perhaps one day short notice diversions won't be a problem for RTT.
PHILIPE
14 Nov 2011
Caerphilly
RTT will only report trains at points which are in the train schedule. A short notice diversion would not be matched up to the schedule.
louis97
14 May 2008
Derby
RTT is able to monitor reports at points not in the schedule, it just won't display them as currently it has no means of doing so - although what is currently in development might make it easier to identify a short notice diversion.
martynbristow
15 Jun 2005
Birkenhead
The exception being when Short Term Planning is used. It depends how they are registered and of it detects them. I have seen some very short notice services added in the past.
Engineering work will show normally.
30 Jan 2013
Do any of the regular services or ECS run via Hyde for route retention purposes?
Some of the services certainly used to around 1993 when I used to visit a friend of mine in Sheffield.
Wolf
9 Jan 2014
Wolf
9 Jan 2014
I'm guessing it's sheffield crew which work it since would imagine they are the only crew except cleethorpes from tpe not to sign via standedge.
Starmill
18 May 2012
Bolton
I'm sure some Sheffield crew do sign Manchester to Huddersfield? By contrast I can't imagine Carlisle or Scottish crews doing so!
