Merseyrail Class 777 introduction updates
trash80
18 Aug 2015
Birches Green
Yes you'd have to have both third rails in parallel (but surely a top contact like the DLR would be better than side contact?) until the new stock had completed the roll-out then start removing the old third rail. I suspect that might push up the cost a bit.
Skie
22 Dec 2008
Merseyrail don't suffer problems with freezing rails that often, Merseyside is fairly well insulated from extreme weather unless the winter is particularly bad. When a forecast says there may be a severe frost they often run ECS around the at risk areas overnight.
507 001
3 Dec 2008
Huyton
Just a thought - I wonder if any consideration was given to ordering the new units with shoes for side contact, rather than top contact, live rail? This was the system used on the Manchester - Bury line and the advantages were reduced risk of the live rail icing up and improved safety. Of course, the live rails themselves would have to be replaced on around 150 miles of track. Not sure if it could be done over two weekends, one for each line! Any comments?
2 weekends?! To do 150 miles of third rail? And both depots?
Tynwald
18 Mar 2016
Most importantly they put kilfrost onto the 3rd rail to stop it icing over. Some of the 507 units (the first 6 I think) had the equipment fitted to the trailers. Then it tranfered to the 501 vehicles, laterly hauled by the class 73's. It is now done by the DB multi purpose units.
It is DLR that is bottom contact. Existing system is top contact, the terminology describes which surface of the third rail is used.
It is physically impossible to have both systems in use together. Also the DLR style bottom contact is speed restricted, possibly as little as 30 mph. I don’t think that allows for the existing speeds used on the routes.
samuelmorris
18 Jul 2013
Brentwood, Essex
DLR units are permitted to travel at up to 50mph I think, and are supposedly rated for 62. I'd have thought that'd be fast enough, and I'm sure such a system could easily be modified to support 75 if needed. Nonetheless, I can't see the current system ever being changed elsewhere, there's far too much of it.
If they were going to change it, putting the wires up would make more sense, though it'd have to be an overhead third rail in the tunnels.
Vinnym
26 Jun 2018
Had 20 mins to kill at Lime Street yesterday morning due to the cancellation of 10.15 Northern service to Wigan North Western (surprise, surprise).
Made the most of this time by viewing the mock up for new Merseyrail trains. They are bright and airy and great to hear they will have aircon. However as has been said before on this thread the seats are very hard and there appears to be fewer of them. The seats no longer have that few inch gap between them, so could be a tight squeeze if you are sitting beside a larger person. This is where the wider aisle space comes from. It is obvious that theses trains have been designed to provide more standing space. Will be interesting to see how the travelling public on Merseyside react to them.
FWIW people were never bothered about the previous layout which had 3+2 with the seats quite close together, much closer than in the Stadler design. But they have had about 10 years of an InterCity quality layout...
FWIW I'm not sure I wouldn't have gone for an LU S8 style layout, i.e. a few bays of 4 for longer distance passengers, and longitudinal and standing for short-distance ones.
507 001
3 Dec 2008
Huyton
A 4 car 777 has the same number of seats as a 3 car 507, but with 50% mores standing space. Yuk.
People did care about the previous 3+2 layout which is precisely why they changed it! I can also guarantee people would have hated longitudinal seating. It was gladly rejected in the survey IIRC. Merseyrail isn’t a busy enough system to warrant the loss of being able to sit together.
61653 HTAFC
18 Dec 2012
Another planet...
Overstatement of the century there, I think!
trainophile
28 Oct 2010
Wherever I lay my hat
Just been around the mock-up myself. The point above about large people being squashed together is a valid one, especially in winter with overcoats on. The guy showing people around said it’s because the gaps between the seats and under the windows were very unhygienic, which is a fair comment I suppose.
Not really looking forward to the new stock, although at least some seats have power sockets.
That could be resolved by making the actual seats about 2" wider.
FWIW, though, my observation is that Merseyrail has a proper "can't be bothered" attitude to proper cleaning and maintenance (above that which is required to keep wheels turning) and always has had. Even the new franchise didn't change that. My favourite bit is where there are door autocloser catch things (which have obviously been swung on by kids, but that's neither here nor there) have been left hanging down in a manner that could poke out the eyes of an unobservant tall person, but there are many examples such as the state of the toilets.
The same people are using Merseyrail as are shopping in Liverpool One (so you can't pin it on the passengers), and the latter would never tolerate the state of disrepair and filth Merseyrail trains and stations quickly end up in.
trainophile
28 Oct 2010
I would suggest that probably the old dears who go into town for their shopping are not the ones who throw their half eaten snacks under the seats, and put their feet on the seats when they can get away with it. Sadly Merseyside has its share of people with no respect for others. It won’t be long before the new seats have sandwiches rammed between what passes for the cushions!
Not too keen on the disappearance of opening windows - aircon is fine until it goes wrong, or is set to high because it’s summer even though it’s cool outside. You always have to carry a warm layer on trains anyway, you never know what you’re going to find.
And from March 2019 (post Brexit) we will be able to ignore European regulations for any stock that remains exclusively within UK.
No, that's not the case.
The ORR has said that all railway TSIs (which we contributed to and accepted over the years) will continue to apply whatever the Brexit outcome.
Not that vehicle numbering is the most important aspect of the rules.
Most of our trains are being built by EU-based manufacturers anyway.
The draft withdrawal deal, if it's approved, means nothing significant will change before the end of 2020 anyway, and maybe not even then.
I wasn't so much talking about littering (at which south WCML travellers are just as bad) - more at ground-in grime, dirt and dust, which just shows a lack of attention.
Train aircon is generally set to a temperature rather than "high" or "low", so it'll be the same all the time. It's set to a temperature that can accommodate everyone, with their coat if necessary, because if it is too hot you don't want me stripping off entirely! :)
61653 HTAFC
18 Dec 2012
Another planet...
It's generously spaced, generous width and all facing. Not sure how it's not an InterCity layout!
OK, no armrests or tables, but those don't affect the *layout*.
The part of your post I bolded says an "InterCity quality layout", which would surely include tables and armrests. If I was travelling 200 miles up to Kings Cross and something like a Merseyrail unit turned up, I'd not be happy!
absolutelymilk
18 Jul 2015
gka472l
29 Apr 2016
Latest Platform 5 combined volume lists the individual car numbers as 427001/428001/429001/430001 etc......
WatcherZero
25 Feb 2010
Battery trial on the class 777 has been pulled, too much heat from the batteries and not enough room to fit cooling equipment without a redesign of the body to increase space.
I would imagine the extended periods in tunnels and slow speeds of the lines compounds the issue by not producing enough airflow.
paddyb6
21 May 2018
So thats the Wrexham/Helsby chances gone
185
29 Aug 2010
Could try Hydrogen. Might take out half of Birkenhead North, but hey, needs no third rail :)
Meerkat
14 Jul 2018
So extensions will have to be 25KV.....
How expensive is it to make a 777 overhead ready, I assume spec is currently passive provision??
Will they still have batteries to get around depots etc?
Lastly when will any of the third rail electrics require major renewal which could assist the business case for a 25KV replacement and extension?
Statto
8 Feb 2011
At home or at the pub
Is 25kV overhead possible in the tunnels?
No, current 507 & 508s just about fit in the tunnels as it is, looking at the mock ups, the new trains look similar height to the current stock, so unless complete redesign of the roof of the new trains, or rebuild of the tunnels which isn't going to happen no chance of 25KV overhead wires.
supervc-10
4 Mar 2012
That's what I thought. Don't the 507/508 and 777 have end doors because the tunnels are so tight too? Like the 717s.
